Catapult SST-50 Thrower: Begin of Sales, Brighter, more Efficient, Regulated Output
ThruNite
ThruNite designs and manufactures their flashlight in Hong Kong, employing its own designers and utilizing its in-house CNC lathes. The company strives to produce the most sophisticated LED flashlights possible, while offering outstanding value through competitive pricing.
ThruNitelights are designed to be more useable by those in need of a high quality illumination tool, more practical than the current ones on the market, and more versatile. The lights are innovatively designed with the consumer’s needs foremost in mind. The company strives to use the best, most up-to-date manufacturing techniques to produce its lights, also.
The Catapult features: an advanced microprocessor for adjustable brightness and regulated by 2 18650., an efficient parabolic reflector, and a double-sided multilayer antireflective coated lens. The Catapult’s ergonomic design enables it to be used for extended periods of time, while providing an anti-slip surface and grip design to lessen any chance of dropping the light.
Features:
World-class super bright Luminus SST-50—with the highest flux bin produced
Maximum of 900 lumens on high
Maximum of 40 hours of runtime on super-low
Advanced PIC provides two modes, including a user-selectable low-level output
Memory mode for last output level used, with four-second separation time between clicks
Cutting-edge reverse polarity protection
Operating voltage between 2.7V to 8.4V
Super-low = 20mA; High = 2.8A
Type III hard anodized 7075AL for durability and wear resistance
Length: 185mm; Head diameter: 58mm; Body diameter: 31mm; Weight: 390g. (Extended tube excluded)
Tactical momentary-on forward click switch
Fluorescent switch cap for visibility in the dark. There is a black silicone tail cap as well.
Tail cap design allows the light to tail stand
Anti-shatter ultra clear lens with double-sided multilayer AR coating
54mm smooth reflector for throw, or OP reflector for a smooth, diffused beam
BATTERY OPTIONS
2*CR123A / 2*RCR123A / 2 x 16340 / 1x 18650 / 1 x 17670. 2*18650 2*17670.
Note: Do not load 4CR123 or 4*16340 batteries in the extended battery tube. Doing so would exceed the maximum input voltage level of the driver.
Voltage cut-off occurs at 2.7V to protect rechargeable batteries. It will flash at 5.2V to mention the battery low for two Rechargeable batteries.
USER INTERFACE
Two Modes are offered:
Tactical Mode and Civilian Mode
Each Mode has two levels
Tactical: High & Strobe
Civilian: High & User-settable Low
To choose the other level in either Tactical Mode or Civilian Mode:
Double click, within three seconds
To have the light remember the last level selected:
Select the level you want within a Mode--then wait 4 seconds before turning light on again. Note: Strobe will be not remembered
To switch from one Mode to the other:
Starting in High, shut the light off by clicking once. After three seconds, press the switch four times--for the first three clicks, no light output will occur. On the fourth click, the light will come on, in High, indicating that you have successfully changed the Mode.
To set the User-settable Low level:
In the Low level of the Civilian mode, shut the light off by clicking once. After three seconds, press the switch four times-- for the first three clicks, no light output will occur. On the fourth click, you will have entered the user-settable low successfully. The light will now ramp up slowly, showing each of the eight possible levels for one-two seconds. To select a level, just shut light off, and on again, immediately.
There are 5 Advantages technique to the ThruNite Catapult:
1- LED - We are using the revolutionary cutting -edge SST-50 LED for extreme brightness -- without artifacts/discrepancies in the beam. We at ThruNite provide you the newest, and the best!
2- Lens - We use ultra clear lens based glass to ensure effective transmission with the addition of double side multilayer AR coatings to ensure maximum light transmission and efficiency. This results in a 98.5% transmittance rating.
3- Reflector - Our optimized OP and SMO reflectors allow you to choose between maximum throw, and a balanced beam of both. They are designed to automotive standards, a parabolic reflector. This design is often used in car lamps in the industry. You can't go wrong with either. Use the one perfect for your application.
4- Driver - We use high quality components in our driver to provide an excellent full featured User Interface, all the while provide roughly 90% efficiency.
5- Design - The light is built as a rugged, high quality tool to suit your needs for many years. It is very ergonomic -- The Catapult is designed with you in mind! We take all suggestions seriously, and have adapted the light to fit the consumer.
Suggest retail pricing:149usd.
Please kindly find link for details!
http://www.cpfmarketplace.com/mp/showthread.php?t=200969
Please kindly contact us for details. we can be reached by
Sales@ThruNite.com
