Dereelight DBS V2
kleinertoto
Dereelight DBS V2/ Tiablo ACE
irgendwie blicke ich im Moment nicht die Unterschiede, vielleicht kann jemand aufklären:
DBS V2 w/ 1SM-2 Cree XR-E 5A Q3 (SMO) - $115
DBS V2 w/ 1SM-2 Cree XR-E WC Q5 (SMO) - $115
DBS V2 w/ 1S Cree XR-E 5A Q3 (SMO) ------ $120
DBS V2 w/ 1S Cree XR-E WC Q5 (SMO) ----- $120
DBS V2 w/ 3SM Cree XR-E WC Q5 (SMO) - --$125
DBS V2 w/ 3SM Cree XR-E 5A Q3 (SMO) ---- $125
DBS V2 w/ 3SD Cree XR-E WC Q5 (SMO) --- $125
DBS V2 w/ 3SD Cree XR-E 5A Q3 (SMO) ---- $125
DBS V2 w/ 3SM Cree MC-E-M (OP) ---$145
Da mit dem Lämpchen liebäugele, wäre es klasse wenn mich jemand auch die "Spur" bringen könnte.
Dank im voraus.
kleinertoto
ja schon,
als newbee habe ich aber noch so meine Verständnisproblem..
Gibt es da eine verständliche Übersetzung??
kleinertoto
Hab hier mal die Beschreibung aus dem Verkaufsthread kopiert:;)
3SD: 3 light output levels (Low/Med/High) 18650 or 17670 battery only.
3SM: 3 light output levels as above, uses 2 x CR123 or 2 x RCR123. Can use 2 x 18650 or 4 x CR123 when optional extension tube is used). Will not work with a single 18650 or 17670. (Old version will, new version will not. Old version is labeled 3.0v to 9.0v, new version is labeled 4.6v to 12.0v)
1S: Single output level, just High. On/Off operation. 18650/17670 battery only.
1SM-2: Also single output level, just High. On/Off operation, but can take 2 x Cr123 or 2 x RCR123, single 18650/17670, OR 2 x 18650, 4 x CR123, 4 x RCR123 when using the optional extension tube.
So that just leaves your choice of emitter:
The R2 is the brightest option, and it has a cool/neutral white WC tint. The Q5 is also cool/neutral white, and is slightly less bright than the R2. You really won't notice the difference with the naked eye, they're really close to each other in brightness.
The 5A Q3 is a bit less bright, but has a really nice warm white tint to it. If you like the color of an incandescent light, and don't generally like LED lights, this one might surprise you.
So let's interpret a sample option, the 3SM 5A Q3:
3 = three light levels
SM = 2 x CR123 or 2 X RCR123, OR 2 x 18650, 4 x CR123 with extension tube
5A Q3 = the Q3 bin of a 5A tint emitter (warm white)
AW: Dereelight DBS V2/ Tiablo ACE
Welche wäre dann bezogen auf Leistung und wenig Modi Euere Empfehlung?? Oder besser auf die Tiablo ACE warten??
kleinertoto
kleinertoto
Nun ja, wie es Blitzlich schon gepostet hat:
für wenige Modi eben ein 1S oder 1SM-2 Modul, je nach dem ob du nur einen Akku benutzt oder eine Konfiguration mit 2 oder mehr Zellen.
Als LED nimmst die Q5 oder R2, wenns um reine Leistung geht.
Meine Wahl fiele auf die MC-E Version. Da gibts dann auch nicht so viele Varianten. Dereelight bietet die DBS jetzt übrigens schon in der Version V3 an :super:
Empfehlenswert ist auf jeden Fall der Extension-Tube, der als Zubehör verfügbar ist, da er den Einsatz von 2 18650er LiIo-Akkus ermöglicht. Bei der hohen Stromstärke (2.1A) kommt man um den wohl nicht herum.
