EXTREMA RATIO: T4000 S RANGER LIMITED EDITION
T4000 S Ranger is a limited edition of only 100 pieces based on our model T4000, a reworking of the Japanese Wakizashi short sword that the Samurai wore at all times in contact with the body.
It is a tactical tool out of time, that does not follow any trend but faithfully respects Extrema Ratio philosophy aimed at satisfying all functional needs.
This model continues the purest Tanto series of Extrema Ratio designed specifically for lovers of the profile of Japanese blades, who do not want to give up typical tactical accessories such as textile sheath and handle in special polymer.
The blade, in Böhler N690 steel hardened to 58 HRC and MIL – C – 13924 burnish, is characterized by the Geotech Camo customization, the innovative and original Extrema Ratio camouflage pattern, created by laser engraving.
The HCS handle is made in Forprene, an elastomer that meets the “NATO standard” for its exceptional resistance to extreme conditions.
The black cordura sheath is equipped with a MOLLE system which allows it to be worn on tactical vests and generic belts and guarantees the transport of the extremely sharp blade in total safety, protecting it from knocks that could reduce its efficiency.
T4000 S Ranger Limited Edition is supplied in an IP67 certified watertight Polypropylene technical case, with pressurization valve, resistant to atmospheric agents, dust and shocks. Inside there is also a double-grain sharpening plate (ceramic abrasive and synthetic diamond) and a metal plate with the numbering of the limited series of 100 pieces.
TECHNICAL SPECIFICATION:
- WEIGHT G.: 264,0
- WEIGHT OZ.: 9,3
- BLADE LENGTH (MM): 174
- BLADE LENGTH (IN): 6.9
- TOTAL LENGTH (MM): 304
- TOTAL LENGTH (IN): 12,0
- BLADE THICKNESS (MM): 4,0
- BLADE THICKNESS (IN): 0,16
- BLADE MATERIAL: BÖHLER N690 STEEL (58HRC)
- BLADE FINISHING: MIL-C-13924 BURNISHING GEOTECH CAMO
- MAIN GRIND: FLAT
- HANDLE MATERIAL: FORPRENE
Extrema Ratio S.R.L.
Via Traversa delle Ripalte 72/74/76/78 - 59100 PRATO - Italy
Tel. +39 0574 584639 - Fax. +39 0574 581312
info@extremaratio.com - www.extremaratio.com
