Halfbreed Blades - OFFICIAL Launch MIK-04 SOFMAK
Halfbreed Blades - OFFICIAL Launch MIK-04 SOFMAK​
Thank you to everyone who joined the MIK-04 SOFMAK preorder event! Your orders are now en route and will arrive in the coming days.
This much-anticipated release is a collaboration with Joseph Teti — former Force Recon Marine, Army Special Forces Green Beret, and CIA SAD/SOG operative. Together, we proudly launch the MIK-04 SOFMAK.
The HALFBREED BLADES SOFMAK is a mission-ready, multi-role fixed blade with two functional cutting edges. The primary edge is designed for combat and utility, with aggressive serrations near the handle and a 5.3-inch blade for exceptional piercing. The secondary edge along the spine handles field tasks like slicing paracord, opening packages, and prepping fire-starting material — helping preserve the main edge’s sharpness.
The SOFMAK includes a robust, jump-rated carry system for flexible, quick access. Mount it horizontally or vertically on a belt or attach via MOLLE to a plate carrier or modular gear. Machined from a solid slab of premium Böhler K340 tool steel with a rugged PVD coating, it delivers top-tier durability, performance, and corrosion resistance.
MIK-04 SOFMAK Specs:​
  • Description: SOFMAK
  • Action: Fixed Blade
  • Blade Steel: K340 ISODUR (59-60 HRC)
  • Blade Edge: Polished Partially Serrated
  • Blade Finish: PVD Coated
  • Blade Style: Drop Point
  • Blade Length: 5.31" (135mm)
  • Blade Thickness: 0.25" (6.5mm)
  • Handle Material: G10
  • Handle Thickness: 0.98" (25mm)
  • Overall Length: 10.31" (262mm)
  • Sheath Type: Injection Molded Plastic
  • Sheath Weight: 3.95oz. (112g)
  • Knife Weight: 11.14oz. (316g)
  • Overall Weight: 15.09oz. (428g)
  • Mounting: Belt & PALS/MOLLE
ORDERS OVER $550 SHIP FREE WORLDWIDE
The Halfbreed Blades name and logo are registered Trademarks of
Halfbreed Blades Australia Pty Ltd (ACN 167 522 536).
Copyright © 2019-2025 Halfbreed Blades Australia Pty Ltd, All rights reserved.
HALFBREED BLADES® is a sister brand to HARDCORE HARDWARE AUSTRALIA®.
