Hi everyone,
I recently bought C80W2, the steel arrived yesterday, here is the chemical analysis:
C 0,82%
Si 0,25%
Mn 0,22%
Mo --
V --
Cr 0,10%
Ni 0,05%
Cu 0,06%
W 0,01%
P 0,030% max
S 0,030% max
I have never worked with this steel before so I hope you can give me some tips about how to heat treat this steel. I intend to make several tanto with the steel and I will be claying it to form a hamon. This steel seemed ideal to make a hamon.
From the information I have gathered this seems like a good heat treatment:
Normalize 2 times by heating to 820 Celcius (1510F), taking it out of the fire, cool till black color, heat up to 820 again, cool to room temperature.
Clay the blade, clay thickness will be about 5mm (1/5 inch).
Heat to 780 Celcius (1440F), soak for a few minutes, then quench in water.
Temper two times at 200 C (390 F) for one hour.
Let me know what you think about this. I am not sure about the normalizing.
Any feedback or tips are welcome.
Louis
C 0,82%
Si 0,25%
Mn 0,22%
Mo --
V --
Cr 0,10%
Ni 0,05%
Cu 0,06%
W 0,01%
P 0,030% max
S 0,030% max
Louis
