Hy!
Dies habe ich kopiert von
Ever-Led
EverLED™ Bulb Features.
· Converts most 1 to 6 cell flashlights to bright, reliable and efficient LED technology.
· Batteries last up to 5 times longer and light is up to 4 times as bright as conventional krypton bulbs.
· Even if run continuously, EverLED™ would last more than 10 years.
· No glass or fragile filament. Impact tolerant and water resistant. Super reliable.
· Housing is made of high conductivity, precision CNC machined brass.
· Single LED is up to 10 times brighter than earlier LED flashlights.
· First flashlight replacement bulb to use LuxDrive™ technology, allowing "one size fits all" use in 1, 2, 3, 4, 5, and 6 cell flashlights. LuxDrive™ electronics are contained within the bulb housing!
· Special light emission pattern takes advantage of your flashlight's existing reflector to create bright beam of light. Creates additional "peripheral light" allowing more effective illumination of scenes.
· LuxDrive™ PowerSqueeze™ circuitry makes full use of the batteries' capacity, unlike other LED lights which only use 20% of the batteries' potential energy. Quickly pays for itself in battery savings, yet without sacrificing light.
· Fully compatible with rechargeable batteries, unlike many conventional flashlights. LuxDrive™ gives a regulated, constant level of light until the batteries weaken, then gradually dims so you don't get "caught short".
· EverLED™ is available in many different colors: white, blue, red, green, yellow, teal
EverLED™ installation instructions:
1) Open flashlight and remove the original incandescent bulb.
2) Drop in an EverLED™ LED replacement bulb.
3) Reassemble the flashlight and enjoy a brighter light with better battery life
BirnencEigenschaften EverLED™.
· Bekehrte die meisten 1 bis 6 Zellentaschenlampen zur hellen, zuverlässigen und leistungsfähigen LED-Technologie.
· Batterien dauern bis 5mal länger und Licht ist bis 4mal, die wie herkömmliche Kryptonbirnen so hell sind.
· Selbst wenn Durchlauf ununterbrochen, EverLED™ mehr als 10 Jahre dauern würde.
· Kein Glas- oder zerbrechlicher Heizfaden. Auswirkung tolerant und Wasser beständig.
· Superzuverlässiges Gehäuse wird von der hohen Leitfähigkeit, bearbeiteter Messing der Präzision CNC gebildet.
· Einzelne LED ist bis 10 Taschenlampen der Zeiten heller als früh LED.
· Die erste Taschenlampenwiedereinbaubirne zum Verwenden der Technologie LuxDrive™, "eine Größe erlaubend paßt allen" Gebrauch in 1, 2, 3, 4, 5 und 6 Zellentaschenlampen. Elektronik LuxDrive™ werden innerhalb des Birnengehäuses enthalten!
· Spezielles helles Emissionmuster zieht Nutzen aus vorhandenem Reflektor Ihrer Taschenlampe, um hellen Lichtstrahl zu verursachen.
· Verursacht das zusätzliche "Zusatzlicht", das wirkungsvollere Ablichtung von Szenen erlaubt.
· Schaltkreis LuxDrive™ PowerSqueeze™ bildet vollen Gebrauch von der Kapazität der Batterien, anders als andere LED-Lichter, die nur 20% der möglichen Energie der Batterien verwenden. Zahlt schnell für sich in den Batteriesparungen, dennoch, ohne Licht zu opfern.
· Völlig kompatibel mit nachladbaren Batterien, anders als viele herkömmliche Taschenlampen. LuxDrive™ gibt ein reguliertes, konstantes Niveau des Lichtes, bis die Batterien schwächen, dann sich verdunkelt stufenweise, also erhalten Sie nicht "kurz" verfangen.
EverLED™ ist in vielen unterschiedlichen Farben vorhanden:
weiss, blau, rot, grün, gelb, türkis
Montagevorschriften EverLED™:
1) Bei der geöffneten Taschenlampe, die ursprüngliche weißglühende Birne entfernen.
2) fallen in eine Wiedereinbaubirne EverLED™ LED.
3) bauen die Taschenlampe wieder zusammen und genießen ein helleres Licht mit besserem Batterieleben.
Noch Fragen
Keine ?
die Preise: sind leider sehr hoch: Bei
theledlight gibt es Rabatt
Grüsse
Martin
PS: Musste zum Postzollamt um es abzuholen
