MadDog Knives
Knifecollector
MadDog WSP1 (Water Safety Program)
Blade Starrett 496-O1 high carbon tool steel. Full flat grinds from 1/4" stock. Hidden full tang. Selectively tempered. 62-63 HRC at edge, 50-54 HRC through tang and spine. Hard chrome.
Grip Black glass/epoxy composite. Strength of 79,000 psi. 1000 volts per mil (.001") dielectric strength. Nonabsorbent and impervious to virtually all chemicals and solvents.
Length Blade:7". Total Length: 11.75"
Sheath Combat sheath is worn on the belt and hangs from a 2.5" loop of seatbelt nylon. The knife is double-retained in the sheath system by a Kydex retention lip which snaps over the guard and a nylon loop/brass snap tie which secures the lower part of the grip to the sheath. It has holes along the rivetted side for tying the sheaths to backpacks or other tactical equipment and has a 1" slot at the bottom for a leg tie.
attachment.php
