New From Spartan Blades: The Pandia Flipper
New From Spartan Blades: The Pandia Flipper​
The Pandia is precision with presence. From the first glance, it speaks to balance, intent, and mastery—an object shaped by discipline, refined by experience, and built to endure. Named for Pandia of Greek mythology, a figure associated with the full moon and the clarity it brings, the knife reflects quiet strength and measured power.
The frame and hardware are machined from 6AL4V titanium, delivering exceptional strength in a thin, lightweight form. Every line is deliberate, every surface resolved. A precision-machined monolithic titanium pocket clip integrates seamlessly into the frame, preserving the knife’s clean, uninterrupted silhouette.
Specifications
  • Designer: Curtis Iovito
  • Blade Length: 3.25"
  • Overall Length: 8.25"
  • Blade Steel: CPM MagnaCut
  • Blade Style: Folding Frame Lock, Spear Point
  • Grind: High Flat Grind for Optimal Slicing Performance
  • Frame: 6AL4V Titanium
  • Pocket Clip: Monolithic Titanium
  • Weight: 4 oz
At its core is a blade made from CPM MagnaCut, realized through Spartan Blades’ deep expertise in heat treatment and steel performance. Years of hands-on experience with advanced blade steels guide a carefully controlled process, including a double deep cryogenic treatment, to achieve a precise balance of edge retention, toughness, and corrosion resistance—MagnaCut, fully expressed.
The spear point blade features a high flat grind, which enhances slicing performance, delivering smooth, precise cuts with minimal effort. A thoughtfully placed sharpening choil ensures the edge can be maintained flawlessly over time.
Deployment is immediate and fluid. The flipper mechanism, equipped with the well-known IKBS bearing system, provides smooth, repeatable action that knife enthusiasts recognize and trust.
The Pandia is designed to inspire at first glance—and to earn respect with every use. It is not defined by trends or excess, but by clarity of purpose and the quiet authority of a tool done right.
