Nexus
wojtas13
Just couple of picts:
Hallo Wojtas13,
schraubst Du damit Deinen PC zusammen oder nimmst Du ihn auseinander? :D Egal, isn hübsches Messer.
Gruß Egbert
PC und ...
Auf dem Schreibtisch liegen noch mehr interessante Messerchen 'rum.
Sauber verarbeitet ist es, das Nexus.
mfg, Stefan.
nice knife, and the handle looks very comfortable, does it also handle this great?
and how about the sheath?
Don't have a sheath yet. I can't tell much about this knife, because I have couple of days. But I' do some testing till the end of next week.
Here a test:
http://www.coltelleriacollini.it/community4/modules.php?name=Forums&file=viewtopic&t=2645
here the traslation in english, Sorry for errors
1 ° test: classical branch on the 6-8 cm of diameter cut in chopping mode with settled beautiful blows, neither one folds eaten away either to say it with few blows
http://img435.imageshack.us/img435/3884/20gu.th.jpg
2° test: Cut of a thread in steel of, the thread in steel e' be cut and the edge of the knife no damaged.
http://img464.imageshack.us/img464/2655/34el.th.jpg
3° test: To penetrate the Nexus within the usual cabinet in steel of the thickness of 1-1,5mm, this test e' be fatal for the tip of the Boker Applegate while for the Nexus and the state easiest to penetrate without to endure some damage, the blows ' have been 2, first e' penetrated of the single ones 3 cm approximately because I have not given sufficient push to the knife while according to entered blow e' until the handle then in order making the photo I have pulled it behind until half approximately.
http://img385.imageshack.us/img385/773/48vb.th.jpg
The knife seemed to have endured numerous scratches on the surface that in truth are reveal to you to be residual of the varnish of the cabinet.
http://img118.imageshack.us/img118/2531/56ti.th.jpg
4° test: I have broken of tiles and a block with the back of the knife, without impediments I have beaten and I milled some blocks, also it seems enough marked here but with one cleaned up as we will see e' returned new!
http://img385.imageshack.us/img385/3351/75sk.th.jpg
5° test: An other branch to chop, this time a branch of greater dimensions, in spite of the tests endured ransom still much good!
http://img118.imageshack.us/img118/4856/86gu1.th.jpg
6° test: knife cleaned up from the returned soil practically new and tries of cut of the 0.25 inch rope with the tip of the knife that had previously penetrated the steel cabinet that therefore could have still given some trouble if not in one be good ... the rope be cut easy.
http://img109.imageshack.us/img109/7166/94dn.th.jpg
wojtas13 you are a very good photographer. :super:
what camera you have?
EDIT: Bilder gelöscht. Bitte zitiert so knapp wie möglich. Vier Riesenbilder für 2 Zeilen Kommentar müssen nicht sein.
-Walter
Previosly I used Minolta x20, now I have Pentax Optio 750z.
Very good camera in a compact and stylish housing.
Great macro.
Movable lcd gives good comfort while photgraphing knives.
And of course a tripod, it is way more important than a good camera.
