Extrema Ratio Police Evo
Extrema Ratio is proud KO present the new POLICE EVO.
This folding knife has been developed togetherwith a Special Italian Police department (department for anaylisis, research and development of materials) and it comes with:
TECHNICAL DATA:
Total length: 220 mm
Blade length: 86 mm
Weight: 255 gr
Serration: no
Blade thickness: 3 mm
Blade steel: N690 (58HRC)
To view the new model of Click the written below
http://www.extremaratioknivesdivision.eu/italiano/brochure/police_evo/eng.html
- standard blade with special rounded shape to avoid injurying while using
- emergency blade (belt cutting blade) with automatic opening and a special additional safe to block the blade while using it.
- marklyn sparkle with special security blockto use it safely
- magnetic screwdriver
- set of accessories (saw, can / bottle opener, rasp). Each one can be fixed to the handle when using it.
- glass breaker
- pocket clip
- cordura sheath which is also holding all accessories and screwdriver
TECHNICAL DATA:
Blade length: 86 mm
Weight: 255 gr
Serration: no
Extrema Ratio Knives Division
VIA TOURCOING, 40/P
59100 PRATO (PO) ITALY
TEL. +39 0574 584639
FAX +39 0574 581312
info@extremaratio.comVIA TOURCOING, 40/P
FAX +39 0574 581312
