Extrema Ratio RAO II
This new version of the well known Extrema Ratio Rao, comes with a new drop blade and an improved upper rounded sides handle for better ergonomic grip.
The extra safe block turns it into a real fixed blade knife allowing hard chopping performances with no risk of injuries.
The sheath hold the knife in open position in case of frequent use, or in close position inside the front pocket. It comes with a diamond sharpener to keep your knife always perfectly sharpened.
- WEIGHT: G.33O
- TOTAL LENGHT: 262mm
- HANDLE MATERIAL: ANTICORODAL
- ANODIZED ALLUMINUM
- BLADE LENGHT: 115mm
- BLADE THICKNESS: 6mm
- BLADE MATERIAL: BOHLER STEEL N690 (58HRC)
- SERRATION ON THE BLADE: NO
- MAIN GRINDING: FLAT PLAN
- BLADE FINISHING: BURNISHING MIL-C-13924
Extrema Ratio Knives Division
VIA TOURCOING, 40/P - 59100 PRATO (PO) ITALY
TEL. +39 0574 584639 - +39 (0)574-574322, +39 (0)574-574084
FAX +39 0574 581312 - MOBILE +39 346-3112135
info@extremaratio.com
http://www.extremaratioknivesdivision.eu
