Presseinfo - Surefire 221 Variable-Output Wristlight - Technical Specifications
Developed with input from active-duty cops, the ambidextrous SureFire 2211 WristLight straps securely to your firearm support-hand wrist and utilizes a virtually indestructible high-performance LED and specially developed optic to unleash 180 lumens of wide, brilliant light with a press of either of two ergonomic switches. In close-quarter armed engagements, this is more than enough light to overwhelm an aggressor and properly identify and assess threats to make more-informed decisions. The 2211 is constructed of lightweight hard-anodized aerospace aluminum and features an adjustable nylon band that is durable and holds the light securely in place. It is powered by a rechargeable lithium-ion battery with a built-in LED fuel gauge that lets you know when it’s time to recharge—which is simply done by using the included USB cable. The 2211 was built for the streets but it’s available to anyone who demands an innovative, hands-free tactical-level illumination tool that can also serve as a handgun light when used with a normal firing stance.
Specifications
  • Output / Runtime -- White Light
  • High 180.0 lumens / 1.25 hours*
  • Med 60.0 lumens / 4.0 hours
  • Low 15.0 lumens / 13.0 hours
  • Tactical Runtime* 1.0 hours
  • Weight w/Batteries 3.7 ounces
  • Batteries Li-ion Integral
*Runtime (at highest setting for multiple-output flashlights) until output drops below 50 lumens
http://www.surefire.com/illumination/wristlights/2211-wristlight.html
  • 2211_PIS_new_version.pdf
