Spyderco - Para 3 Lightweight Salt CPM MagnaCut
Spyderco - Para 3 Lightweight Salt CPM MagnaCut​
C223SYL
PARA® 3 LIGHTWEIGHT SALT® CPM® MAGNACUT®​
Sleek, simple, and fearlessly corrosion resistant, the long-awaited Para® 3 Lightweight Salt may be the ultimate everyday carry knife for those who work in and around the water. This knife takes the innovative Para 3 Lightweight platform and supercharges it with a SpyderEdge™ blade crafted from CPM® MagnaCut®—a revolutionary powder metallurgy stainless steel that offers an incredible balance of edge retention, toughness, and corrosion resistance. Its open-backed fiberglass-reinforced-nylon (FRN) handle is injection molded in bright yellow to ensure high visibility and features Spyderco’s Bi-Directional Texturing™ for a secure grip, even with wet hands. To complete the package, the knife’s streamlined Compression Lock®, reversible deep-pocket carry clip, and all other hardware are all precision machined from ultra-corrosion-resistant materials.
Origin: Made in USA
  • Closed length: 4.29 in / 109 mm
  • Overall length: 7.21 in / 183 mm
  • Blade length: 2.92 in / 74 mm
  • Edge length: 2.58 in / 66 mm
  • Blade thickness: 0.145 in / 3.7 mm
  • Weight: 2.4 oz / 68 g
  • Blade Steel: CPM MagnaCut
  • Edge Options: SpyderEdge
  • Grind Type: Full-flat
  • Lock Mechanism: Compression Lock
  • Handle Material: Fiberglass-reinforced nylon
  • Carry Option: Left/Right Tip-Up
Steel: Constructed from CPM® MagnaCut®, a steel known for its exceptional balance of wear resistance, toughness, and corrosion resistance. It maintains a high level of edge retention while performing reliably in demanding environments.
Lock: Equipped with a Compression Lock mechanism, the knife offers a high-strength locking system positioned for secure operation and reduced risk of unintentional disengagement. The design allows for one-handed closing without placing fingers in the blade path
Handle: Bright yellow FRN, chosen for its high strength-to-weight ratio and dimensional stability. A bi-directional texturing™ pattern enhances grip security under a range of conditions.
