Good Day everyone yes, I am here to announce another new model from SUNWAYMAN, it's the powerful V20C, you know from its name that this is another fully variable light, compatible with both 18650 and CR123 batteries.
Rules as always, stated on my fist post, please refer to it if you are new here
Now comes the details and pictures, please enjoy.
438 Lumens, Multi-functional, Fully Variable, Magnetic Control Tactical Flashlight
--CREE XM-L T6--
The 2011 V20C is the latest powerful tactical flashlight from SUNWAYMAN. This light has a brand new structure, and an innovative multi-functional, fully variable magnetic control ring. The V20C’s fully variable magnetic control ring marks a major breakthrough in technology. It perfectly integrates the super-low standby current, has a wide range of output; 0.5 to 438 lumens, plus a strobe mode, and the V20C feels great in your hand and is easy to use! Fitted with a CREE XM-L T6 LED, the light generates up to 438 lumens’ output. Compatible with both two CR123A batteries and one single 18650, the V20C maintains a great balance between high output and runtime. The V20C is an elegant flashlight with a solid structure and convenient size. This light is an ideal lighting tool for every-day-carry, outdoor activities, military defense and hunting.
Multi-function, Fully Variable, Magnetic Control Rotator Ring
Since SUNWAYMAN entered the market, its innovative and user-friendly magnetic control interface has become the brand’s symbol. The V20C brings the fully variable magnetic control technique to another level; it perfectly integrates the super-low standby current, has a range of 0.5 to 438 lumens output and integrates a strobe mode.
CREE T6 LED, Output Up to 438 Lumens
Fitted with a CREE XM-L T6 high powered LED, the V20C generates up to 438 lumens’ output, and can shine as little as 0.5 lumens. The fully variable interface combined with the high-efficiency optical system makes this light ideal for a variety of lighting circumstances.
Reverse Battery Protection Design, Effective Protection Circuit
The V20C is designed to prevent the flashlight from reverse batteries, so there is no need to worry about damages to the battery or circuit. Even if you insert a battery reversely, the protection circuit will effectively protect the flashlight, battery and your safety.
Uses 2 x CR123A or 1 x 18650 Battery
The V20C is compatible with both 2 x CR123A batteries and 1 x 18650 battery, which can satisfy your demands for battery versatility and efficiency.
Features
● CREE XM-L LED, with a lifetime of up to 50,000 hours;
● Digital Sensor Magnetic Control system - slightly twist the Rotator Ring from left to right to select desired mode from super-low current standby, output ranging from 0.5 to 438 lumens, to strobe function:
Max: 438 Lumens (2hrs)
Min: 0.5 Lumen (120hrs)
Strobe: 438 Lumens
● Constant current circuit, constant output
● Effective range of 300 meters
● Uses two 3V CR123A batteries or one single 18650 battery
● Working voltage: 3~8.4V
● High quality reflector maintains great throw distance and spread with an ideal beam pattern
● Dimensions: 134mm (length) x 32mm (head diameter) x 25.5mm (tail diameter)
● Weight: 120g(battery excluded)
● Aerospace-grade aluminum alloy
● Military Specification Type III- hard anodized body
● Waterproof, in accordance with IPX-8 standard
● Ultra-clear tempered glass lens resists scratches and impacts
● Tactical forward click switch with momentary on
● Tail stand capable- can be used as a candle
● Accessories: Metal tactical ring, lanyard, holster, O-ring, rubber cap
But there is more than the above, you will be finding a little surprise when you get the real V20C in hands.:超级:
--CREE XM-L T6--
Features
Strobe: 438 Lumens
