Sunwayman-T20C T6
sunwayman
Find a review here: http://www.messerforum.net/showthread.php?t=98573
438 Lumen Flashlight with Patented Tactical and Adjustable Switch System
CREE T6 LED, CR123A or 18650 Battery
The SUNWAYMAN T20C utilizes a creative and innovative tactical and adjustable switch system, which has been patented by SUNWAYMAN. Its brand-new design allows for easy operation and provides a powerful performance. Combined with a tactical momentary switch that makes mode-switching effortless, the T20C sets a new standard for the development of tactical flashlights. The output reaches as high as 438 lumens, and the T20C offers 4 user selectable output modes, including an attention grabbing tactical strobe. This is an ideal lighting tool for hunting, law enforcement, outdoor activities and much more.
Brand-new Patented Tactical Switch and Adjustable Output System
The SUNWAYMAN T20C utilizes a newly developed adjustable switch system designed to enhance and simplify the user experience. Simply depress the tailcap switch for tactical momentary-on and to switch modes. This brand-new mechanical structure has no traditional plastic press button; therefore the switches never burn out.
CREE T6 LED, Max Output 438 Lumens
Fitted with the newest Cree XM-L T6 LED and combined with a high efficiency drive circuit, the SUNWAYMAN T20C can output up to 438 lumens. The T20C is outstandingly bright for its size class, and is an ideal tool for searching, hunting, hiking, driving, etc.
Solid Tactical Exterior, Easily-detachable Tactical Ring
The T20C has a sleek appearance and a solid and practical structure equipped with an easily-detachable tactical ring, and an all-steel tactical bezel. Its body is designed for a comfortable and effective grip, and it can be used as a defensive weapon when necessary.
Features
● CREE XM-L T6LED, with a lifetime of up to 50,000 hours;
● Three levels of constant output and one strobe mode (below is the output and runtime of using one single 2600mAH 18650 battery)
Three levels of constant output:438 Lumens (2.5hrs) → 70 Lumens (35hrs) → 10 Lumens (200hrs)
Strobe mode:438 Lumens
● Patented new tactical switch system, only by pressing the tail cap switch for both momentary-on and mode-switching
● Constant current circuit, constant output
● Effective range of 180 meters
● Compatible with both 2*CR123A(16340)batteries and one single 18650 battery
● Working voltage:2.5~10V
● High quality reflector maintains great throw distance and spread with an ideal beam pattern
● Dimension:133 mm (length)* 32mm(head diameter)*25.4mm(body diameter)
● Weight:120g(battery excluded)
● Aerospace-grade aluminum alloy
● Military Specification Type III hard anodized body
● Waterproof, in accordance with IPX-8 standard
● Ultra-clear tempered glass lens resists scratches and impacts
● Tactical forward click switch with momentary on
● Accessories: tactical ring, lanyard, O-ring, rubber cap
