Right hand Takamura R2 Gyuto 210 mm from a local Chef, who got it as a birthday present from his wife.
The knife has already been used for two months in the commercial kitchen and it was time for it's first resharpening, which i did yesterday on a Paper Wheel with 15 micron diamond compound and then deburred on a second Paper Wheel with 0.25 micron diamond compound.
The idea was to make an edge that would do both slicing & pushcutting well, and also to remove as little steel as possible from the fine and thin R2/SG2 blade @ 63-64 HRC.
The new edge measures +/- 20 degrees inclusive and can whittle a chest hair from root-to-tip at about 4 centimeters from the point of holding, and after a few test cuts into a old piece of beechwood cutting board.
I took these pics with an old Ipad and actually wanted to erase them again as being not good enough until i enlarged the last picture twice.
At first i thought i saw small dirt spots on the new bevel, but those tiny white specks were actually the sliced off peaks of the micro-dot structure on the inside of the flimsy plastic blade protector sleeve.
The owner of the Takamura R2 just sent me the link to this clip, in which he uses a grape to test the new edge:
https://m.youtube.com/watch?v=ID9KZW0d9ss&feature=youtu.be
