Trance thumbstuds...
Daywalker
Aloha ALL,
I know I saw it done somewhere, I just don't remember where...:hmpf:
BUT, has anyone removed the thumbstuds on their Trance, and if so, how do they come off?:confused:
God bless and mahalo for your time!
Chad:ahaa:
www.clbdesign.info
Boker International Design Team:steirer:
Do you remember the pic of the modified Trance you got from me? - the one with the removed flipper and the "drilled through" thumbstud...
Well, it is quite easy to remove the thumbstuds, they are just screwed together - perhaps it not so easy without scratching the surface...
mfg, stubenhocker
mfg, stubenhocker
Aloha stubenhocker,
Sorry...but not really.:(
However, can one remove the studs then, with two pliers? Scratching the blade is not too much of an issue...:argw:
God bless and can you post a "reminder picture"?:hehe:
Chad:ahaa:
Mahalo Morales!
Great seeing you...but uh...I cannot make head or tail out of what was being said!:rolleyes:
The Trance pics looks like the stud was "sheered"?
God bless and thanks!
Chad:ahaa:
Sorry Chad, my bad! He removed the pin and riveted a piece of steel to the blade.
I hope this helps, take care,
Carsten
Yes, it is (easy)! With two pliers or one plier and a bench vise.
Yes, we can! ;)
mfg, stubenhocker
:super:!!!
Vielen Dank!!! I remember now stubenhocker! However...
Does anyone have a pic with the studs removed completely?:glgl:
God bless and mahalo!
Chad:ahaa:
You have to turn against clockwise to loosen them - but be sure you get the "male" one - it's much easier then.
It is no problem to put the studs back - but they will be scratched, because at least mine were to tight to get them off with a piece of rubber between the pliers.
mfg, stubenhocker
