Jenni
Moderator Forum Kizlyar und BRKT
Hallo zusammen
Hier werden wir wie schon in den Vorjahren den Produktionslauf für das Jahr 2013 veröffentlichen.
Der Produktionslauf unterliegt wie immer Schwankungen, das heißt: es kann immer mal wieder das ein oder andere Modell vorgezogen oder zurückgestellt werden.
Index:
Delivered The run is over and shipped to the Distributors- ausgeliefert
Delivering The run has started to ship and will continue to ship until 100% shipped to the Distributors - in der Auslieferung
In Assembly The blades are totally ready for starting to build the run- Griffmontage
In Blade Grinding The Blades are having the Rough Initial Grind put in them-
In Surface Grinding The Blades are being uniformly surfaced so that they are flat and have all of the heat treat slag removed from them
In Heat Treat The Blades are in the process of being heated - Quenched - Cryo Treated - Triple Tempered - Straightened and then Shank Drawn to soften the tangs
In Water Jet Cutting The Steel is Delivered and the job is in line for Cutting and then Drilling out the Holes.
Lil' Canadian CPM3V - Delivered Im Shop
100 Bravo-1 CPM3v Partial - Delivered(more in a couple of weeks)
Rogue US Distributors - Delivered
Bravo-1 CPM 3V Fill-In US Distributors - Delivered
Bravo-1 A-2 US Distributors - Delivered
Rogue EU Distributors - Delivered Im Shop
Bravo-1 CPM3V EU Distributors - Delivered Im Shop
Bravo-1 A-2 EU Distributors - Delivered Im Shop
Bushcrafter - 3V Delivered Im Shop
Drop Point Hunter - CPM154 - Long Bolster - Delivered
Blackjack Model 4 Boot Knife - Delivered
Blackjack Bush Companion - Delivered
Blackjack Lite-Hawk - Delivered
Blackjack Model 5 - Delivered
STS-8 Fill-In - Delivered
Gameskeeper A-2 wird in Kürze erwartet
Montana Guide A-2 - wird in Kürze erwartet
Gameskeeper - CPM 4V -wird in Kürze erwartet
Essential CPM-M-4 - wird in Kürze erwartet
Fox River CPM3V Fill-In - wird in Kürze erwartet
Aurora A-2 - Delivering wird in Kürze erwartet
Bravo-II A-2- In Blade Grinding
More Rogues and Club Knives - In Blade Grinding
Scandi - In Assembly
Karambits for the Grind in - In Assembly
Pro Series Brush Knives for the Grind-In - In Assembly
Misc A-2 Blanks for the Grind-In - In Assembly
Steak Knife Sets - CPMS35VN - In Surface Grinding
Bird & Trout Knife CPMS35VN Fill-In In Surface Grinding
Gunny A-2 Fill-In - In Surface Grinding
Gameskeeper II A-2 - In Heat Treating
Montana Guide II A-2 - In Heat Treating
Fox River A-2 - In Heat Treat
Highland Special A-2 - In Heat Treat
Woodland Special A-2 - In Heat Treat
Nomad - Small Hunter A-2 - In Water Jet Cutting
BJK Model 1-7 200 PC - In Water Jet Cutting
BJK Model14 Halo Attack - 120 PC -In Water Jet Cutting
Blackjack Mamba - A-2 - In Water Jet Cutting
BJK Neck Knife - 200PC - In water Jet Cutting
Bravo-1.5 CPM3V Fill In - In Water Jet Cutting
Bravo-1.5 Field Model CPM3V Fill-In - In Water Jet Cutting
2013 Filet Knife Canadian Sportsman 1A - In Water Jet Cutting
Gunny - Bohler Elmax Steel - In Water Jet Cutting
Pathfinder 20CV S.S.
Aurora CPM 3V
Bravo-1LT. CPM3V
Petty Z - 154CM
Large 10+ Inch Blade Chef - CPMS35VN
Blackjack Neck Knife - 154CM - In Water Jet Cutting
Bravo-III 3V - (.275" + 3V)
BJK Model 3 - A-2
Bravo-Folder - No Specs or Info at this time
Pro Thrower 1075
Boundary Rider Bowie - A-2
BJK Model 2-7
Essential II CPM4V
Wilderness Explorer SPF-2 S.S. (Full Tang River's Edge Style)
Estella Wilderness Knife - CPM3V
Scagel Small Hunter A-2
Scagel Small Bowie A-2
Scagel Small Skinner A-2
Essential Folder - No Specs or Info at this time
Bravo-2.5 A-2
STS-2 DLT 154CM
Pro-Scalpel II A-2
Moro Barong
BJK Smaller 125
Pro Series Brush Knife A-2 5160
Rogue Bowie II - A-2
Bushcrafter Folder - No Specs or Info at this time
Canadian Camp Knife II
Mini-Rogue
BJK 14-8 Attack Knife
Mini Special Hunting Knife
Grasso-Bolo Basic - A-2
Mini-Grasso Bolo
Grüße Jenni
Index:
Aurora CPM 3V
Bravo-1LT. CPM3V
Petty Z - 154CM
BJK Model 3 - A-2
Pro Thrower 1075
BJK Model 2-7
Essential II CPM4V
Bravo-2.5 A-2
STS-2 DLT 154CM
Pro-Scalpel II A-2
Moro Barong
BJK Smaller 125
Mini-Rogue
Mini-Grasso Bolo
Grüße Jenni
