EXTREMA RATIO: BF2 CD M390 TACTICAL GREY
EXTREMA RATIO: BF2 CD M390 TACTICAL GREY​
BF2 CD M390 TACTICAL GREY is a full-size EDC knife, ideal for being professionally employed by military and police officers. Thanks to its functionality, this versatile every-day-carry is also perfect for many everyday situations.
The handle features the new ‘Tactical grey’ colour and is composed of two full handle scales with the characteristic lowered slots to engage the opening pins without having them protruding from the blade when closed. The grip is firm and comfortable. The clip is reversible and becomes a useful and convenient support for the thumb in the reverse grip.
The blade features a flat grind and a particularly thick and resistant drop tip; it is coated with a carbon-based DLC (Diamond-Like Carbon) superficial treatment, which makes it hyper-resistant to abrasion and chemical aggression.
The steel is Böhler M390 heat treated to 61 HRC. Thanks to a powder metallurgical production process, it guarantees cutting effectiveness, resistance to wear and oxidation over time.
The blade locking mechanism is the time-tested liner lock, supported by a manually operated safety mechanism protected by a guard.
TECHNICAL SHEET​
  • Weight g.: 142
  • weight oz.: 5
  • Blade Length (mm): 87
  • Blade Length (in): 3.4
  • Total Length (mm): 213
  • Total Length (in): 8,4
  • Blade Thickness (mm): 3
  • Blade Thickness (in): 0,12
  • Blade Material: BöHLER M390 STEEL (61HRC)
  • Blade Finishing: EXP DARK
  • Main Grind: FLAT
  • Handle Material: ANTICORODAL ANODIZED ALUMINUM
Extrema Ratio S.R.L.
Via Traversa delle Ripalte 72/74/76/78
59100 PRATO - Italy
info@extremaratio.com
