EXTREMA RATIO BLACK WARFARE
Today we are releasing Extrema Ratio Misericordia Black Warfare, which is a limited series of only 500 pieces that will be exclusively sold by retailers who have already ordered this model.Where can you find these retailers? You will just need to go to our website, open the product page of the Misericordia Black Warfare and you will find a pop-up listing their contact details.
Product description
Extrema Ratio Misericordia Black Warfare is a limited series of only 500 pieces. It features all the characteristics of the famous Misericordia adopted by the 4th Alpine Paratroopers Regiment, which contributed to its development and testing, and choose it for its unique characteristics that make it particularly suited for ambush combat.The blade is milled out of Böhler N690 steel, heat treated to 58 HRC for best combination between edge retention and toughness. It is 118 mm (4.65”) long and 4 mm (0.16”) thick with a flat grind. The knife weights just 87 g (3.1 oz). The blade features a spear-point shape with a full length fuller, which makes it even lighter, and has a false double edge to 3/4 of its length. Its finishing, Black Warfare, is made of the innovative and original Geotech Camo pattern by Extrema Ratio, laser-engraved on the surface. The grip maintains the typical ergonomic Extrema Ratio profile and is made in glass reinforced nylon to offer maximum toughness under all circumstances, even in the harshest use.
The characteristic ring at the pommel helps the soldier to get a better grip for a safer and more effective thrust, enhancing exponentially the combat effectiveness of the Misericordia. The kydex sheath can be attached to a belt-clip, ULTICLIP and malice clip, as well as to a M.O.L.L.E. webbing using paracord.
There is also an optional high resistance nylon sheath with two adjustable loops for attaching it to a M.O.L.L.E. webbing. Misericordia Black Warfare is delivered in a weather, dust and shock resistant polypropylene IP67 certified waterproof case with pressurization valve, which carries also the Kydex sheath, double ulticlip, double grit sharpener (ceramic and synthetic diamond) and a metal plate bearing the progressive number within the limited series.
TECHNICAL SPECIFICATION:
- TYPE: FIXED BLADE
- USE: TACTICAL
- WEIGHT G.: 87
- WEIGHT OZ.: 3,1
- BLADE LENGTH (MM): 118
- BLADE LENGTH (IN): 4.64
- TOTAL LENGTH (MM): 233
- TOTAL LENGTH (IN): 9,17
- BLADE WIDTH (MM): 4
- BLADE WIDTH (IN): 0,16
- BLADE MATERIAL: BÖHLER N690 (58HRC) STEEL
- BLADE FINISHING: MIL-C-13924 BURNISHING, GEOTECH CAMO
- MAIN GRID: FLAT
- HANDLE MATERIAL: FIBER GLASS REINFORCED NYLON (FRN)
Extrema Ratio S.R.L.
Via Traversa delle Ripalte 72/74/76/78 - 59100 PRATO - Italy
Tel. +39 0574 584639 - Fax. +39 0574 581312
info@extremaratio.com - www.extremaratio.com
