EXTREMA RATIO: CAIMANO NERO N.A. RANGER XXV ANNIVERSARIUM LIMITED EDITION
Today, 8th November 2023, we are releasing the second limited edition specifically created to mark the end of the twenty-fifth anniversary of Extrema Ratio.
Extrema Ratio Caimano Nero N.A. Ranger XXV Anniversarium is a limited edition of just 250 pieces that preserves all the characteristics of the famous Caimano Nero N.A., a non-automatic version of the tactical knife that Extrema Ratio has supplied to the G.O.I. (Operational Raiders Group) of the Italian Navy.
Caimano Nero N.A. Ranger XXV Anniversarium joins the limited series that Extrema Ratio has created to mark the end of the twenty-fifth year of activity.
The blade is a 4 mm thick asymmetrical spear point. The serrated part of the edge allows to cut highly resistant cables and fabrics without losing its sharpening. Its finishing is made with Geotech Camo, the innovative and original laser-engraved pattern by Extrema Ratio.
The grip is made of two anodized anticorodal aluminum handle scales in the brand-new Tactical Mud color. The bottom part of the handle is designed to enhance the grip for a rapid extraction of the knife from the pocket. The DLC-coated titanium clip can be positioned in three different angles on both sides allowing to conceal the knife as much as possible inside the pocket.
Extrema Ratio Caimano Nero N.A. Ranger XXV Anniversarium Limited Edition is delivered in a weather, dust and shock resistant polypropylene IP67 certified waterproof case with pressurization valve; this includes a commemorative coin of the twenty-fifth anniversary of Extrema Ratio and a metal plate bearing the progressive number within the limited series.
Extrema Ratio Caimano Nero N.A. Ranger XXV Anniversarium Limited Edition is available at our best retailers and on extremaratio.com.
TECHNICAL SPECIFICATION:
- TYPE: FOLDING KNIFE
- WEIGHT G.: 162
- WEIGHT OZ.: 5,71
- BLADE LENGTH (MM): 93
- BLADE LENGTH (IN): 3.66
- TOTAL LENGTH (MM): 231
- TOTAL LENGTH (IN): 9,1
- BLADE THICKNESS (MM): 4
- BLADE THICKNESS (IN): 0,15
- BLADE MATERIAL: BÖHLER N690 STEEL (58HRC)
- BLADE FINISHING: MIL-C-13924 BURNISHING GEOTECH CAMO
- MAIN GRIND: FLAT
- PARTIAL SERRATION (MM): 20
- PARTIAL SERRATION (IN): 0,78
- HANDLE MATERIAL: ANTICORODAL ANODIZED ALUMINUM
Via Traversa delle Ripalte 72/74/76/78 - 59100 PRATO - Italy
Tel. +39 0574 584639 - Fax. +39 0574 581312
info@extremaratio.com - www.extremaratio.com
