Extrema Ratio DMP
DMP is a multipurpose knife characterized by a remarkable versatility of use thanks also to its middle size. The drop point blade with a reinforced tip is particularly useful for the hardest use.
The full flat grinding gives excellent cutting characteristics. The sheath is minimalist; most of the fabric has been cut off; it has got a 2nd level retention system, remembering the style of the model it was inspired by. The main shell is injection-molded in shockproof nylon.
The secondary retention system is reversible for ambidextrous users. The DMP model is available in Black, Desert, HCS, Ranger Green, Wolf Gray versions.
DMP HCS
DMP Wolf Grey
DMP Desert
DMP Ranger Green
Discover on WWW.EXTREMARATIO.COM
