Extrema Ratio - Fulcrum C FH - Shrapnel OG FH
Extrema Ratio is proud to present the new version of Fulcrum C and Shrapnel OG with a more comfortable 127 mm FULL HANDLE.
FULCRUM C is the compact version of the FULCRUM, which it equals in robustness and sturdiness. Its downsized blade (only 4" 1/3 long) and handle make it comfortable to carry and easily concealed. The included hard sheath can be worn vertically, horizontally or obliquely (at a 45° angle), and sports a single automatic pressure-activated security lock for quick, easier drawing and sheating. This makes the FULCRUM C an intuitive, rapid-use knife, ideally suited to emergencies or self-defense. The original version of the FULCRUM C comes with a 3.93in compact handle, the Full Handle version comes with a more comfortable 5in handle.
SHRAPNEL OG is a truly versatile “back up” knife with marked combat qualities. Its leaf-shaped blade is flat ground at a characteristically low angle to a wide, extraordinarily sharp edge. The included hard sheath can be worn vertically, horizontally or obliquely (at a 45° angle). Unlike the older model it supersedes, the SHRAPNEL OG hilt design does not include a guard. The original version of the SHRAPNEL OG comes with a 3.9in compact handle, the Full Handle version comes with a more comfortable 5in handle.
Available soon in the best knives shops and on www.extremaratio.com
Extrema Ratio S.a.s.
Via Traversa delle Ripalte 72/74/76/78 - 59100 PRATO - Italy
Tel. +39 0574 584639 - Fax. +39 0574 581312
info@extremaratio.com - www.extremaratio.com
