EXTREMA RATIO: MISERICORDIA RANGER XXV ANNIVERSARIUM LIMITED EDITION
On 17th November 2022 Extrema Ratio celebrated its first 25 years of activity. Over the last year our company has celebrated this important anniversary by presenting new special editions and limited series dedicated to this major event.
Starting today until 16th November Extrema Ratio will present 4 new limited editions to mark the end of the twenty-fifth anniversary.
Extrema Ratio Misericordia Ranger XXV Anniversarium is a limited edition of only 400 pieces. It features all the characteristics of the famous Misericordia adopted by the 4th Alpine Paratroopers Regiment, which contributed to its development and testing, and chose it for its unique characteristics that make it particularly suited for ambush combat.
Misericordia Ranger XXV Anniversarium joins the limited series that Extrema Ratio has created to mark the end of the twenty-fifth year of activity.
The blade is milled out of Böhler N690 steel, heat treated to 58 HRC for best combination between edge retention and toughness. It is 118 mm (4.65”) long and 4 mm (0.16”) thick with a flat grind. The knife weighs just 87 g (3.1 oz). The blade features a spear-point shape with a full length fuller, which makes it even lighter, and has a false double edge to 3/4 of its length. Its finishing is made with Geotech Camo, the innovative and original laser-engraved pattern by Extrema Ratio.
The grip maintains the typical ergonomic Extrema Ratio profile and is made in glass reinforced nylon to offer maximum toughness under all circumstances, even in the harshest use. The characteristic ring on the pommel helps the soldier get a better grip for a safer and more effective thrust, enhancing exponentially the combat effectiveness of the Misericordia.
Misericordia Ranger XXV Anniversarium Limited Edition comes with 2 sheaths, both in desert colour: the first, made of kydex, can be attached to a belt clip, Ulticlip and malice clip (optional accessories are sold separately). It is also possible to attach it to the M.O.L.L.E. system webbing by means of a paracord. The second, made of high-resistance Nylon, is equipped with 2 adjustable loops that allow it to be attached to the M.O.L.L.E. system.
Misericordia Ranger XXV Anniversarium Limited Edition is delivered in a weather, dust and shock resistant polypropylene IP67 certified waterproof case with pressurization valve; this includes the kydex and nylon sheaths, a commemorative coin of the twenty-fifth anniversary of Extrema Ratio and a metal plate bearing the progressive number within the limited serie.
Extrema Ratio Misericordia Ranger XXV Anniversarium Limited Edition is available at our best retailers and on https://extremaratio.com/prodotto/misericordia-ranger-xxv-anniversarium-limited-edition/?lang=en.
TECHNICAL SPECIFICATION:
- TYPE: FIXED KNIFE
- WEIGHT G.: 87
- WEIGHT OZ.: 3,1
- BLADE LENGTH (MM): 118
- BLADE LENGTH (IN): 4.64
- TOTAL LENGTH (MM): 233
- TOTAL LENGTH (IN): 9,17
- BLADE THICKNESS (MM): 4
- BLADE THICKNESS (IN): 0,16
- BLADE MATERIAL: BÖHLER N690 STEEL (58HRC)
- BLADE FINISHING: MIL-C-13924 BURNISHING GEOTECH CAMO
- MAIN GRIND: FLAT
- HANDLE MATERIAL: NYLON / FIBER GLASS (FRN)
Via Traversa delle Ripalte 72/74/76/78 - 59100 PRATO - Italy
Tel. +39 0574 584639 - Fax. +39 0574 581312
info@extremaratio.com - www.extremaratio.com
