Extrema Ratio presents KIRI
Extrema Ratio presents KIRI​
Kiridashi is a type of Japanese knife, a cutting multipurpose tool. One of its peculiarities is the asymmetric bevel; only one of the two sides has a grind while the other remains flat.
Extrema Ratio has reinterpreted this traditional Japanese knife according to its style, giving it a more tactical look than the original. KIRI features a particular tip designed to obtain a high penetration efficiency while maintaining its characteristic chisel grind. Extrema Ratio KIRI is available in Dark Stone and Satin finish, both in Böhler N690 steel hardened to 58 HRC. The handle is made of two black anodized anticorodal aluminum scales. The pre-shaped Kydex sheath is equipped with metal eyelets for inserting a paracord, which also allow it to be attached to a M.O.L.L.E. system webbing. KIRI can be accessorised with the following options (sold separately):
BELT CLIP that allows you to attach the sheath to a belt. ULTICLIP SLIM 3.3 (we recommend at least two) that allows you to attach the sheath not only to a belt but also to pockets, trousers, jackets, shirts and t-shirts. Available in two versions, Dark Stone and Satin.
TECHNICAL SPECIFICATION:
  • TYPE: FIXED BLADE
  • WEIGHT G.: 112
  • WEIGHT OZ.: 3.95
  • BLADE LENGTH (MM): 60
  • BLADE LENGTH (IN): 2.36
  • TOTAL LENGTH (MM): 190
  • TOTAL LENGTH (IN): 7,48
  • BLADE MATERIAL: BÖHLER N690 STEEL (58HRC)
  • BLADE THICKNESS (MM): 5
  • BLADE THICKNESS (IN): 0,19
  • BLADE FINISHING: DARK STONE / SATIN
  • MAIN GRIND: FLAT
  • HANDLE MATERIAL: ANTICORODAL ANODIZED ALUMINUM
Discover more on EXTREMARATIO.COM: Kiri – Extremaratio (https://extremaratio.com/categoria-prodotto/knives/multipurpose-knives/kiri-en/?lang=en)
Extrema Ratio S.R.L.
Via Traversa delle Ripalte 72/74/76/78 - 59100 PRATO - Italy
Tel. +39 0574 584639 - Fax. +39 0574 581312
info@extremaratio.com - www.extremaratio.com
