EXTREMA RATIO: TUSCAN
EXTREMA RATIO: TUSCAN​
Tuscan is a tribute to our region, Tuscany. This land is characterized by breathtaking landscapes, hills, mountains, cities, villages, rivers, and the Tyrrhenian Sea washing its coasts. Tuscany is also home to three out of six Italian military special forces, confirming the strategic importance and relevance of this territory at a national and international level.
Tuscan is a multi-role knife that can be completely at ease in any type of environment. This knife stands out in military and tactical fields for its versatility in various contexts, from surveillance and patrol operations to combat scenarios. Its adaptability also makes it ideal for urban areas where it is necessary to move quickly and with agility. At the same time, Tuscan lends itself perfectly to outdoor, survival and bushcraft use.
Tuscan is extremely easy to handle. It is characterized by a full tang blade in BOHLER N690 steel (58 HRC), lightened in several points beneath the handle (including a hole positioned in its center). This allows you to move the weight of the knife towards the tip, thus increasing the impact force and facilitating chopping and batoning operations. The blade allows you to carry out such different operations thanks to its particular grinding, thinner near the handle and thicker at the tip. While the tip area lends itself to chopping and batoning, the part near the handle is perfect for cutting.
Unlike grinding, the sharpening on the entire blade remains homogeneous. The pommel can also be used as a glass breaker.
The handle is composed of 2 ergonomic grips featuring a new original Extrema Ratio design made of G10 material. This new handle allows Tuscan to be used comfortably with both standard and reverse grip, suitable with or without gloves.
The ambidextrous Cordura sheath is equipped with a thigh strap to be attached to the side, and M.O.L.L.E system webbings for wearing it on tactical vests and generic belts. Tuscan is available in Black Satin version (handle and sheath in black color, satin blade) and Green version (handle and sheath in green color, burnished blade).
TECHNICAL SHEET
  • Weight g.: 437,5
  • weight oz.: 15,43
  • Blade Length (mm): 167
  • Blade Length (in): 6.57
  • Total Length (mm): 306
  • Total Length (in): 12,04
  • Blade Thickness (mm): 6
  • Blade Thickness (in): 0,23
  • Blade Material: BöHLER N690 STEEL (58HRC)
  • Blade Finishing: SATIN
  • Main Grind: FLAT
  • Handle Material: G10
Shop: TUSCAN BLACK SATIN – Extremaratio (https://extremaratio.com/prodotto/tuscan-black-satin/?lang=en)
Extrema Ratio S.R.L.
Via Traversa delle Ripalte 72/74/76/78
59100 PRATO - Italy
info@extremaratio.com
