Extremia Ratio - New Multipurpose Knife TASK J.
Extrema Ratio is proud to present the new multipurpose knife TASK J.
This knife has been developed together with material experts of Jagdkommando Unit, the Austrian Army special force.
It is a multipurpose knife with double guards to avoid accidentally slipping of the hand on the blade. It comes with standard desert side sheath with automatic retention mechanism and protective slap. A fireball flint and striker is placed inside the sheath.
TECHNICAL SHEET
  • Weight g.: 315
  • Weight oz.: 11.11
  • Blade Length (mm): 158
  • Total Length (mm): 289
  • Blade Thickness (mm): 6,3
  • Blade Material: ACCIAIO BöHLER N690 (58HRC)
  • Blade Finishing: MIL-C-13924 BURNISHING
  • Main Grid: FLAT
  • Handle Material: FORPRENE
http://www.extremaratio.com/prodotti/coltelli-lama-fissa/multiruolo/task-j.html?___store=en
Extrema Ratio S.a.s.
Via Traversa delle Ripalte 72/74/76/78 - 59100 PRATO - Italy
Tel. +39 0574 584639 - Fax. +39 0574 581312
info@extremaratio.com - www.extremaratio.com
