Extremia Ratio - NK3 model in Karambit version
Extrema Ratio is proud to present the new NK3 model in Karambit version.
The tanto blade is made of Bohler N690 steel with blood-draining slot and ring in the back part of the handle.
It comes with a quick-release kydex sheath. It can be worn at your neck, or fixed to the belt or to the M.O.L.L.E. system with the suitable Extrema Ratio accessories (not included).
It is produced in black, stone washed and desert warfare version.
This knife extends our neck knife series. It comes with N690 steel tanto blade, blood-graining slot on the blade and ring in the back part of the handle. Thanks to its kydex sheath it can be carried at the neck or in case it is assembled with other special accessories (to be bought separately) it can be fixed to the belt or to the Extrema Ratio cordura M.O.L.L.E system sheath.
It comes in black, stone washed and desert warfare versions. Available but not included: BELT-CLIP (for attaching sheath to a belt), polymer UNDER SHIRT SYSTEM (for concealed carry).
Available in the best knife shops and on www.extremaratio.com.
TECHNICAL SHEET
  • Weight g.: 95
  • Weight oz.: 3.35
  • Blade Length (mm): 70
  • Blade Length (in): 2.75
  • Total Length (mm): 172
  • Total Length (in): 6.77
  • Blade Thickness (mm): 6.3
  • Blade Thickness (in): 0.24
  • Blade Material: BöHLER N690 STEEL (60HRC)
  • Blade Finishing: MIL-C-13924 BURNISHING
  • Main Grid: FLAT
  • Handle Material:BöHLER N690 STEEL (60HRC)
