Ich denke von Bildern kann man keine Qualitätsaussage machen.
Waren die Erwartungen vielleicht zu hoch?
@HankEr: Hät ich auch nicht schlecht gefunden. Hab Peter Hjortberger
angeschrieben und mal nachgefragt. Hier ist seine Antwort:
The folder will have a standard flat ground blade with a
secondary edge.
The reason for using the convex edge is for adding both strength
and sharpness to the edge and these qualities are especially
required on survival knives which are exposed to hard use.
I don't believe a folder will be used that tough and for that
reason, we're not using the convex edge concept on this
folder.
It's also a matter of blade design and technical equipment - if
we had added the convex ground, we hadn't been able to
apply the kind of round area by the thumb stud and this had
forced us to find other designs and other places for the thumb
stud. So, making a folder is a very complex matter!
However, this is something that the final owner of the knife can
apply by himself. The blade is fairly thick (3 mm) and has got
enough steel for making personal adjustments.
Viele Grüsse von Rage
secondary edge.
folder.
der folder sieht nämlich IMO ziemlich gut aus.
