final beauty contest - Spring- und Automatikmesser
Harkins "Rados" Triton I
Specs:
Length open: 21,7 cm
Length closed: 12,4 cm
Blade length: 9,2 cm
Blade thickness: 2,99 mm
Steel: Rados Turkish Twist Damascus
Handle material: hot gun blued steel with 59 inches of 24 kt gold wire inlays plus a 2,0 mm sapphire in the firing button
Weight: 157 grams
Comes in padded pouch
(specks in some of the pics are dust particles in reality)
@kwakster Das beste was ich bisher gesehen habe, die Harkin Triton, einmalig.
mein kleiner Beitrag, Microtech mini UMS😎
Microtech prototype custom Daytona Double Action OTF van 08/2008, with dagger logo and serial number 11.
Specs:
Length opened: 19,0 cm (including "glassbreaker")
Length closed: 11,0 cm
Blade length: 8,0 cm
Blade thickness: 3,29 mm
Steel: most likely S30V (not marked)
Handle material: hard anodized 6061 aluminum without inserts
Weight: 88 grams
Microtech custom Ultratech VI Double Action OTF
Very rare.
Specs:
Length open: 21,3 cm (including "glassbreakers")
Length closed: 12,6 cm
Blade length: 8,6 cm
Blade thickness: 3,2 mm
Blade material: Carbon fiber/Titanium/Carbon fiber laminate
Handle material: housing from hard anodized 6061 aluminum with carbon fiber top and actuator.
Weight: 64 grams
Microtech custom Scarab Tanto Double Action OTF with partly polished blade & polished carbon fiber handle inserts.
Sterile except the Scarab logo.
Specs:
Length open: 21,2 cm (including "glassbreakers")
Length closed: 12,5 cm
Blade length: 9,0 cm
Blade thickness: 3,26 mm
Steel: most likely S30V stainless
Handle material: hard anodized 6061 aluminum with polished carbon fiber inserts
Weight: 117 grams
Microtech HALO III Single Action OTF from 07/2005
Specs:
Length open: 23,9 cm
Length closed: 13,7 cm
Blade length: 10,1 cm
Blade thickness: 3,72 mm
Weight: 103 grams
Microtech custom Ultratech VI Double Action OTF with single edge stainless damascus blade.
Specs:
Length open: 20,3 cm
Length closed: 11,8 cm
Blade length: 8,5 cm
Steel: stainless Damascus
Handle material: hard anodized 6061 aluminum.
Weight: 93 grams
