Die wichtigsten Merkmale der neuen JetBeam:
Model: C-LE
LED: CREE 7,090 XR-E P4
Max brightness: 80 lumens
Reflector: Aluminum Reflector
Lens: Sapphire crystal w/ internal AR coating
Material: T6061 aluminum alloy
Coating: Military Type HA-III
Power source: AA cells : 1.0-1.5V
Electric circuit function: bright - low bright - high bright - Blink (10Hz)- SOS
bright:Approximately 40 lumens, (7 hours)
low bright:Approximately 20 lumens, (30 hours)
high bright:Approximately 80 lumens (2 hours)
Switch: Twisty
Waterproofing : 10 meters
Diameter : Head 19.5mm, Tail 17mm, length 85mm
Weight: 32 grams (do not contain battery)
Hab mir vor wenigen Tagen eine bestellt und hoffe auf das Eintreffen ab Mitte Januar....
Heinz
