Kydexscheide selbstgemacht
Eben, gar nicht mehr. Früher halt ein wenig Klebeband herumgewickelt und die Stellen an denen es dann doppelt war hat man halt gesehen. Da es aber auch ohne Kleben prima geht spare ich mir selbst diesen Aufwand :hehe:.
Hi, I hope you guys don't mind me posting in English. I'm from Belgium and my German is not that good. Sorry for this.
It's my first post, so if I'm doing anything wrong on this forum, just let me know.
I noticed that this thread is about making kydex sheats.(I hope it is, if not, please delete this post)
I have some pics about me making my first kydex sheat. From the beginning till the end.
Here it goes:
First the neccesary materials: I went to pick up a camping mat in the adventure store and a heat gun (to remove paint) in the hardware store.
Pic 2: I taped the blade, because I read that you should do this. Otherwise, the kydex fits too tight around the blade.
As you can see, I made a sheat for a balisong. This kind of knife needs a very tight fit, so in my second attempt (see pics below), I didn't use the tape.
This is a 1mm kydex sheat.
I placed the Kydex on my old anvil to heat it up safely. This wasn't neccesary. It's not too hot to handle.
I didn't need the pliers.
Sorry, no pics of me bending the hot Kydex. (didn't have time). But here I'm forming the kydex around my balisong. I used my full weight.
This is how the stuff gets out.
Now I had to make a pocket clip for it. I take a 2mm kydex sheat for this.
The finished product. I used two bolts to attatch the clip to the sheat.
Front view. Notice that I took off the sharp edges with a sanding paper and a file.
Here you can see how I used bolts to attatch the clip to the sheat.
This was my first attempt. But because I wasn't totally happy with it, I tried again...
I changed the design a bit and used 2mm kydex instead of 1mm.
Look at the difference:
Thanks for watching,
dv11
ich bastle im Moment gerade daran ein Holster für mein Miltary zu bauen,längs zum Gürtel. Habe aber das Problem wenn ich die Konturen schön herausarbeite kann ich das Messer nur noch schwer ziehen,wenn nicht sieht das Holster nicht so gut aus.
Kennt ihr das Problem ?
Super Beitrag DV11
Welcome deviant11
and thanks for posting this illustrative tutorial.
Btw. posting in english is far better than in Swahili.
@Curtado: Probier doch mal mit ner Chicago Screw die Spannung einzustellen.
Schöne Bilderanleitung!
Vielleicht noch zur Ergänzung wegen dem Raufstellen:
Ich habe mir erst wie eine Presse gebastelt und dann aber festgestellt das ich mehr Druck durch die Methode mit dem Raufstellen erzeugen kann. Druck kann man IMHO garnicht genug haben! Ich benutze inzwischen sehr kleine Platten zum Pressen (mehr Druck) stelle mich rauf und drücke mich nach unten. Damit sollte ich so auf 90 kilo kommen. Meine selber gebaute Presse hat dies nicht hergegeben weil sie nicht so soliede war. ;)
Für mich (und wohl die meisten hier) reicht diese Methode, sie ist billig und einfach. Wer das professionell machen möchte sollte aber IMHO eine gute Presse bauen.
El
ich trage mich mit dem Gedanken, ein Neckknive zu machen.
Das natürlich auch eine Scheide braucht. Ich habe bis jetzt fast nur Kydex gesehen:
MUSS es Kydex sein oder geht es auch mit Leder? Rausfallen sollte es natürlich nicht *g*
Hobby
@deviant11:
cool pics.. i like it :)
hab mir heute endlich mal material für ne gescheite presse gekauft.
1x holzrest 60x40x1,8cm zugeschnitten auf 20x30cm 2,55eur
2x streifen 50x30x1,8cm s.o.
2x schanier 8,2x4,4cm 1,4xeur pro stück
10x spax aus restbeständen der familie 0,0 :)
dazu kommt dann noch ein stück einer alten isomatte und a weng kleber.
feddisch ist meine presse.
die kosten lassen sich noch weiter reduzieren, wenn man irgendwo ne alte spanplatte und/oder schaniere abstauben kann :)
ergebnisse werden (hoffentlich) nächste woche gepostet..
