NEWSLETTER EXTREMA RATIO - EXPEDITION SERIES
Expedition Series is the new range of tools dedicated to professional explorators.
The Expedition Series knives offer the same performance, reliability and high quality as any other Extrema Ratio tactical tool provided to the military special forces and law enforcement.
Included in this series are Kreios Expeditions, Selvans Expeditions, Sethlans Expeditions and Satre Expeditions.
KREIOS EXPEDITIONS:
Just like its original model, Kreios, Kreios Expeditions was developed and designed in collaboration with Master Advanced F.I.S.S.S. Instructor Daniele Dal Canto (Italian Federation of Sports and Experimental Survival), who dubbed it the “off-road” of edged tools. Its design is not just meant for a specific use, but for an extremely versatile multi-purpose tool for a vast array of outdoor activities.Its ergonomics, weight and size make the Kreios Expeditions highly effective at carving a path through dense foliage, especially when keeping a safe distance from thorny or otherwise dangerous vegetation. Because of its sturdiness, it also performs excellently as a heavy field work machete, in such duties as felling trees or chopping firewood.
The length of its 12” ¾ “full flat” cutting edge combined with its 11° downward blade-to-grip angle and hefty 22 ½ oz. weight yield an extraordinary cutting capability and very high tolerance to tensile stress. Contemporary geometries and materials meld with Malaysian and African traditions into a heavy duty field work tool which doubles as a weapon of defense and offense in a pinch.
Kreios Expeditions has a desert forprene handle and a BÖHLER N690 (58HRC) blade steel with MIL-C-13924 burnishing and a superficial stone washed finishing (DARK STONE finishing).
It comes with a desert cordura sheath with MOLLE system, a safety carry shoulder belt, a mini puch containing a paracord with flammable filament, which can be used in case of emergency and/or difficult climatic conditions, and a Firesteel for lighting fires.
SELVANS EXPEDITIONS:
Just like its original model, Selvans, Selvans Expeditions was developed as a collaboration between Extrema Ratio and Master Advanced F.I.S.S.S. instructor Daniele Dal Canto (Italian Federation of Sport and Experimental Survival). It is the result of a modification of the ONTOS – a military survival knife – designed to enhance its effectiveness as a civilian tool.A longer handle and a heavier blade enable enhanced chopping and cutting action. It comes with a desert cordura sheath with MOLLE system, a safety carry shoulder belt, a mini puch containing a paracord with flammable filament which can be used in case of emergency and/or difficult climatic conditions, and a Firesteel for lighting fires.
The improved survival kit (to be bought separately) includes: whistle, pocket chain saw, water purifying tabs, compass, copper wire, fireball flint and striker, LED light, 2.5 mts paracord and whetstone.
SETHLANS EXPEDITIONS:
Just like its original model, Sethlans, Sethlans Expeditions is a fixed blade tool born to face a wide range of situations as well as a back-up blade. Sethlans Expeditions was designed in collaboration with Daniele Dal Canto, Master Advanced F.I.S.S.S. Instructor (Italian Federation of Sports and Experimental Survival). It has a BÖHLER N690 (58HRC) blade steel with MIL-C-13924 burnishing and a superficial stone washed finishing (DARK STONE finishing).The knife comes with G10 desert scales that feature the characteristic ergonomic design of Extrema Ratio handles. They can be removed by releasing the skeletonized structure of the knife, that allows maximum lightness with minimum thickness. For lovers of extreme customization, the full-tang structure allows the handle to be covered with a paracord.
The sheath is composed of a part in very light and minimalist Kydex. It can be disassembled and adapted for both left and right handed users. The addition of an optional belt clip allows the knife to be positioned both vertically and horizontally and makes the sheath much more versatile than the textile version.
It is also equipped with a mini pouch with M.O.L.L.E. system containing a paracord with flammable filament, which can be used in case of emergency and/or difficult climatic conditions, and a Firesteel for lighting fires.
SATRE EXPEDITIONS:
Just like its original model, Satre, Satre Expeditions is a pocket-sized, light and extremely resistant fixed blade knife. Given its characteristics, it can be employed in a large variety of activities and fields or as a part of an EDC kit (Every Day Carry).It was designed in collaboration with Daniele Dal Canto, a Master Advanced F.I.S.S.S. instructor (Italian Federation of Sport and Experimental Survival). It can be worn as a neck knife thanks to its Paracord 550 lanyard. This way, it is possible to keep it vertical with the handle facing down. The pre-shaped Kydex sheath has eyelets, allowing to apply both lanyard and accessory holder.
The ULTICLIP carry solution (only available on extremaratio.com) allows to clip the sheath together with not only belts, but also pockets, trousers, jackets, shirts and t-shirts. ULTICLIP gives the possibility to position the knife both vertically and horizontally and allows a more accessible use for left and right handed.
The full-tang skeletonized structure allows the customization of the knife by using the Paracord as an handle cover.
Satre Expeditions has a BÖHLER N690 (58HRC) blade steel with MIL-C-13924 burnishing and a superficial stone washed finishing (DARK STONE finishing). It comes with a pre-shaped desert kydex sheath on which it can be attached a Firesteel for lighting fires.
Discover the new Expedition Series on extremaratio.com!
Extrema Ratio S.R.L.
Via Traversa delle Ripalte 72/74/76/78 - 59100 PRATO - Italy
Tel. +39 0574 584639 - Fax. +39 0574 581312
info@extremaratio.com - www.extremaratio.com
