NEWSLETTER EXTREMA RATIO: HARPOON F RANGER XXV ANNIVERSARIUM LIMITED EDITION
NEWSLETTER EXTREMA RATIO: HARPOON F RANGER XXV ANNIVERSARIUM LIMITED EDITION​
Today, 16th November 2023, we are releasing the last limited edition specifically created to mark the end of the twenty-fifth anniversary of Extrema Ratio.
Extrema Ratio Harpoon F Ranger XXV Anniversarium Limited Edition is available only on extremaratio.com.
Extrema Ratio Harpoon F Ranger XXV Anniversarium is a series made of only 100 pieces, joining the limited editions that Extrema Ratio has created to mark the end of its twenty-fifth year of activity. This model draws the curtains on the year dedicated to this important milestone.
Extrema Ratio Harpoon F Ranger is an exceptional multi-purpose knife for both tactical and survival purposes.
Its solid blade, made of Böhler N690, has a width of 6,3 mm (0.25”) and features a modified spear-point shape.
The flat grind and its profile tapered at the point contribute to lighten it, ensuring perfect balance.
The false serration on its back is designed to bring out its function if geared to a pole and used as a harpoon.
It is 21 cm long, which is unusual for Extrema Ratio. This length was chosen to maximise the performance of the knife in every application.
The blade features the Geotech Camo customization, the innovative and original laser-engraved pattern by Extrema Ratio.
The hcs-coloured grip is one of Extrema Ratio classics; an ergonomic handle made of Forprene, material that guarantees an excellent grip and damping of oscillations for a much more comfortable prolonged use, also on heavy duty.
The desert-coloured cordura sheath, which is delivered in a separate box, is equipped with belt loops.
Harpoon F Ranger XXV Anniversarium is delivered in a weather, dust and shock resistant polypropylene IP67 certified waterproof case with pressurization valve; this includes a commemorative coin of the twenty-fifth anniversary of Extrema Ratio and a metal plate bearing the progressive number within the limited series.
TECHNICAL SPECIFICATION:
  • TYPE: FIXED BLACK
  • WEIGHT G.: 355
  • WEIGHT OZ.: 12.52
  • BLADE LENGTH (MM): 210
  • BLADE LENGTH (IN): 8.26
  • TOTAL LENGTH (MM): 343
  • TOTAL LENGTH (IN): 13.46
  • BLADE THICKNESS (MM): 6.3
  • BLADE THICKNESS (IN): 2.45
  • BLADE MATERIAL: BÖHLER N690 STEEL (58HRC)
  • BLADE FINISHING: MIL-C-13924 BURNISHING GEOTECH CAMO
  • MAIN GRIND: FLAT
  • HANDLE MATERIAL: FORPRENE
DISCOVER MORE ON EXTREMARATIO.COM
Extrema Ratio S.R.L.
Via Traversa delle Ripalte 72/74/76/78 - 59100 PRATO - Italy
Tel. +39 0574 584639 - Fax. +39 0574 581312
info@extremaratio.com - www.extremaratio.com
