NEWSLETTER EXTREMA RATIO: VERSA
Available in Expeditions and Satin version
Versa combines innovative design with unparalleled functionality. The name, Versa, perfectly embodies the characteristics of this knife; its versatility makes it suitable for a variety of situations, showing its adaptability both in urban environments such as an EDC (Every Day Carry) knife, and in more adventurous contexts such as outdoor, survival, bushcraft, hunting as well as in tactical scenarios. It is also ideal as a backup knife. This knife is ready to satisfy every need by combining style and practicality in a single tool. Versa comes in two distinct models: Versa Satin, perfect for everyday use, and Versa Expeditions, more suitable in outdoor, survival and bushcraft contexts.
Both models are made of 58 HRC heat-treated Böhler N690 steel. The Satin version has a satin blade and a black thermoformed kydex sheath, while the Expeditions features a MIL-C-13924 burnish, and a stone washed (Dark Stone) finish. Versa Expeditions comes with a desert-coloured thermoformed kydex sheath to which you can attach a Firesteel for lighting fires (included in the box).
Versa is a fixed-blade knife with a monolithic structure, milled out of a single piece of Bohler N690 steel. The ergonomics are designed to ensure maximum comfort and safety during use. The skeletonized full-tang structure allows you to customize the handle by covering it with paracord, further expanding the possibilities of use and customization of the knife. The total length is 180 mm (7”) with a Tanto profile blade. The kydex sheath is designed for a quick and safe extraction of the blade.
In neck-knife mode, Versa can be easily carried around the neck thanks to a 550 paracord lanyard. It can also be carried on the belt thanks to a belt clip (optional) or attached to pockets, trousers, jackets and shirts with one or more ULTICLIPs (optional). Both solutions are suitable for left- as well as right-handed. It is also possible to attach the sheath to MOLLE system webbings.
Versa stands out not only for its design and high-quality materials, but above all for the versatility it offers, making this knife a valuable ally in many situations.
TECHNICAL SHEET
- Weight g.: 110
- weight oz.: 3.88
- Blade Length (mm): 80
- Blade Length (in): 3.15
- Total Length (mm): 180
- Total Length (in): 7.08
- Blade Thickness (mm): 6.3
- Blade Thickness (in): 2.48
- Blade Material: BöHLER N690 STEEL (58HRC)
- Blade Finishing: DARK STONE or SATIN
- Main Grind: FLAT
- Handle Material: BöHLER N690 STEEL (58HRC)
Extrema Ratio S.R.L.
Via Traversa delle Ripalte 72/74/76/78
59100 PRATO - Italy
info@extremaratio.com
