Presseinfo Extrema Ratio - Heavy Folder HF2
Extrema Ratio is proud to present the new Heavy Folder HF2, available with Drop and Tanto blade and in Black and Desert Warfare version.
This folding knife is projected for those who are looking for sturdiness and reliability of a fixed blade but also for compact sizes. Its N690 steel blade is available with Drop or Tanto point. For standard use the well known liner lock is enough safe. In case of hard extreme works it is requested to insert the steel pin in the proper hole to cross the handle and the blade, obtaining in this way a sturdy and reliable knife as much as a fixed blade. The steel clip can be removed or even placed on the opposite site of the handle by replacing it with the second supplied clip.
It comes in four different versions: HF2 D BLACK, HF2 D DESERT WARFARE, HF2 T BLACK, HF2 T DESERT WARFARE.
TECHNICAL SHEET
Weight g.: 319,5
Weight oz.: 11,27
Blade Length (mm): 124,5
Blade Length (in): 4,90
Total Length (mm): 305,5
Total Length (in):12,03
Blade Thickness (mm): 5,6
Blade Thickness (in): 0,22
Blade Material: BöHLER N690 STEEL (58HRC)
Blade Finishing: MIL-C-13924 BURNISHING
Main Grid: FLAT
Handle Material: ANTICORODAL ANODIZED ALUMINUM
Extrema Ratio S.a.s.
Via Traversa delle Ripalte 72/74/76/78 - 59100 PRATO - Italy
Tel. +39 0574 584639 - Fax. +39 0574 581312
info@extremaratio.com - www.extremaratio.com
