Presseinfo: Nitecore Official launch of SENS series flashlight today!
7th July, the day you’ve been longing for! Nitecore Official launch of SENS series flashlight today! Nitecore SENS series with its innovative use of the Active Dimming Technology (ADT) making it the smartest flashlight ever!
What is ADT??
With the flashlight switched off, turn on the light with the head pointed straight up. The light will access the active dimming function immediately . An acceleration sensor is built in the SENS AA flashlight, which can continuously detect the angle of the light and work with the light’ s mico-computer to select the appropriate output. For example, when it detects a parallel position, the built-in micro-computer will assume a higher output is appropri ate and increase output to illuminate a longer distance. When it detects a verti cal position, micro-computer will decrease output so to save battery life, ex tending runtime of SENS up to 5-8 times.
For more details about SENS Series, please click here: http://www.nitecore.com/productList.aspx?cid=112
What is ADT??
