All three Enuff knives feature skeletonized full-tang construction for strength and light weight. The blades are ground from VG-10 stainless steel, a workhorse material that offers a superior balance of cutting performance, corrosion resistance, edge retention, and ease of sharpening. The clip point and leaf-shaped blades are both plain edged and full-flat ground to yield exceptional edge geometry for precision cutting chores and point utility.
All three Enuff blades have a thoughtfully placed section of jimping (grooved texture) on the spine for enhanced control during use. They also feature identical scales injection molded from durable fiberglass-reinforced nylon. The scales are contoured to provide a hand-filling grip and boast Spyderco’s signature Bi-Directional Texturing™ pattern—a series of opposing angled steps radiating out from the center of the handle to ensure superior traction and a non-slip grip.
The handle shape brackets the hand comfortably, providing both a functional guard to prevent it from moving forward and a gently hooked butt for control during pull cuts and ease of drawing from the sheath. A generously sized lanyard hole also allows the attachment of a fob or lanyard for additional security.
All three Enuff knives use the same sheath design. Injection molded from polymer, it features two “ears” at the mouth that snap around the leading edge of the handle scales to hold the knife securely in place when sheathed. A thumb “push-off” on one side of the mouth supports an easy draw with simple thumb pressure, while the universal design of the sheath cavity allows all three knives to be inserted with the edge facing in either direction. All Enuff sheaths come complete with Spyderco’s versatile G-Clip attachment, which supports both belt carry and clip-style inside-the-waistband carry. The G-Clip is configurable for vertical, horizontal, or diagonally canted carry and can be attached to both sides and both faces of the symmetrical sheath. The sheath also includes multiple mounting holes to allow both high and low-ride attachment of the G-Clip.
