Spyderco byte May 2023 - The Golden Stone™/Webfoot®™ Set Now Shipping
Spyderco byte May 2023 - The Golden Stone™/Webfoot®™ Set Now Shipping​
Spyderco is proud to announce that the set containing both the Golden Stone and Webfoot sharpeners (308FCBN) is in stock and now shipping. Both these sharpeners feature a unique design that provides a perfect 40-degree included angle (20 degrees per side) when tilted from side to side. Placing either stone in the plastic base included with the set reduces the angle to 30 degrees (15 degrees per side).
The Webfoot’s aggressive 600-mesh Cubic Boron Nitride (CBN) abrasive removes steel quickly and is ideal for reprofiling edges or sharpening very dull knives to a utility edge. For touch ups or to achieve a more refined edge after using the Webfoot, the Golden Stone features a fine ceramic abrasive. The unique designs of both sharpeners include rounded edges, grooves, and flat areas to provide multiple abrasive surfaces that sharpen all blade profiles, serrated edges, and tools of all shapes and sizes.
The Golden Stone and Webfoot are both designed to be used dry and do not require any water, oil, clamps, or electricity. They can be used on any flat surface and come complete with protective suede pouches that do double duty as non-slip mats during the sharpening process.
The 308FCBN set includes one Golden Stone, one Webfoot, two suede pouches, one plastic base, and an illustrated instruction book that explains how to use the sharpeners to put an edge on practically any cutting tool in your home. All these items come packaged in a single box suitable for storage as well as shelf or hanging display.
