Various custom Microtech
kwakster
Microtech custom Ultratech VIII Double Action OTF with stainless steel handle & blued carbon steel Damascus dagger blade from 09/2008 with serial number 001.
Specs:
Length open: 20,5 cm
Length closed: 12,0 cm
Blade length: 8,5 cm
Blade thickness: 3,28 mm
Steel: blued carbon steel Damascus
Handle material: satin finished stainless steel
Weight: 162 grams
Custom "Winter" Scarab Double Action OTF with polished dagger blade, silver handle with matching inlays, translucent Lexan slider, oversized titanium "glassbreaker", and complete with padded pouch.
Specs:
Length open: 22,5 cm (including "glassbreaker")
Length closed: 13,9 cm
Blade length: 9,0 cm
Blade thickness: 3,25 mm
Steel: most likely S30V stainless
Handle material: hard anodized 6061 aluminium with grip tape inlays
Weight: 106 grams
Microtech custom Scarab Double Action OTF with stainless Damascus dagger blade from 08/2006.
Specs:
Length open: 21,8 cm (including "glassbreaker")
Length closed: 12,5 cm
Blade thickness: 3,23 mm
Steel: stainless Damascus
Handle material: hard anodized 6061 aluminum with blued titanium screws & glassbreaker
Weight: 118 grams
Microtech custom Ultratech VI Double Action OTF
Specs:
Length open: 21,3 cm (including "glassbreakers")
Length closed: 12,6 cm
Blade length: 8,6 cm
Blade thickness: 3,2 mm
Blade material: Carbon fiber/Titanium/Carbon fiber laminate
Handle material: housing from hard anodized 6061 aluminum with carbon fiber top and actuator.
Weight: 64 grams
Microtech custom Scarab Tanto Double Action OTF
Specs:
Length open: 21,2 cm (including "glassbreakers")
Blade thickness: 3,26 mm
Handle material: hard anodized 6061 aluminum with polished carbon fiber inserts
Weight: 117 grams
Microtech prototype custom Daytona Double Action OTF with blued carbon Damascus blade from 08/2008 and serial number 002.
Specs:
Length open: 19,0 cm (including "glassbreaker")
Length closed: 11,0 cm
Blade length: 8,0 cm
Blade thickness: 3,29 mm
Steel: blued carbon Damascus
Handle material: hard anodized 6061 aluminum with polished carbon fiber inlays
Weight: 84 grams
Microtech custom Scarab Double Action OTF with polished dagger blade & handle inlayed with black rayskin, blued titanium hardware & glassbreaker with ball bearing.
Specs:
Steelt: most likely S30V stainless (not marked)
Handle material: hard anodized 6061 aluminum with black rayskin inlays
Weight: 104 grams
