Length open: 23,0 cm
Length closed: 13,0 cm
Blade length: 10,0 cm
Blade thickness: 4,45 mm
Steel: 154CM with black coating
Handle material: hard anodized 6061 aluminium with Kraton inlays
Weight: 125 grams
Microtech Lightfoot L.C.C D/A Carbon from 09/2001 (4th generation with anodized aluminum bolsters)
The knife can be opened manually with the thumbstuds, but also automatically by swiveling the left bolster a bit to the right.
Specs:
Length open: 21,0 cm
Length closed: 11,9 cm
Blade length: 9,0 cm
Blade thickness: 3,77 mm
Steel: 154CM stainless
Handle material: Carbonfiber scales & anodized aluminum bolsters on steel liners
Weight: 167 grams
Microtech CMTX5-A from 10/2004
This knife opens by pushing on the end of the pocketclip, underneath which is the actuator which releases the blade.
Specs:
Length open: 20,6 cm
Length closed: 11,6 cm
Blade length: 8,9 cm
Blade thickness: 3,23 mm
Steel: S30V stainless with black coating
Handle material: brown canvas Micarta on titanium liners
Weight: 112 grams
Microtech Nemesis II Single Action OTF from 06/2003
The knife opens automatically by pushing the button, after which the blade can be pulled back with a lever inside the back of the handle.
Specs:
Length opened: 21,6 cm
Length closed: 12,2 cm
Blade length: 9,2 cm
Blade thickness: 3,75 mm
Steel: most likely 154CM stainless (not marked)
Handle material: hard anodized 6061 aluminum
Weight: 94 grams
Length open: 21,5 cm
Length closed: 12,7 cm
Blade thickness: 4,44 mm
Steel: most likely 154CM, with a boron carbide coating
Weight: 116 grams
Microtech Scarab Executive Tanto, and outside of the claw logo on the handle the knife is sterile (no markings)
Specs:
Length open: 20,4 cm
Length closed: 11,7 cm
Steel: most likely S30V stainless
Handle material: hard anodized 6061 aluminum without inserts
Weight: 115 grams
Microtech HALO III Single Action OTF from 07/2005.
Specs:
Length open: 23,9 cm
Length closed: 13,7 cm
Blade length: 10,1 cm
Blade thickness: 3,72 mm
Steel: most likely S30V (not marked)
Weight: 103 grams
