Wade & Butcher Boone fixed blade
kwakster
My most recent find is this Wade & Butcher "Boone" carbon steel hunting knife.
It was discovered together with several other vintage hunting knives in an old leather hunting bag from the 1930's somewhere in Amsterdam.
The steel has gotten a dark grey patina from being stored inside the sheath for decennia.
On the blade the letters "ILLWELL" are very faintly visible, and through Google i found that originally it spelled "GILLWELL", which is the 144 acre sight North of London given to the Scouts in 1919 and now the worlds historical site for scouts.
It seems that the change from "GILLWELL" to "GILWELL" took place when Baden Powell was made the first Baron Baden-Powell of Gilwell in 1929.
So in 1919, when the first Wood Badge course was held, it was Gillwell Park.
If the info from Google is correct that would date my knife to have been manufactured between 1919 and 1929, although the sheath is probably not original to the knife but most likely from Scandinavian origin.
What do you guys think ?
Hello,
Again a really good and interesting find!
Unfortunately I‘m not familiar with those kind of knives or their history. But what I‘m able to judge you are a keen and successfull „Knife-Hunter“ and collector having even old catalogues handy! Keep going on.
Abu
Thx, i think i will do just that, :)
Currently i'm doing a bit of online research on what kind of steel was used in these knives, and according to this old ad the Boone blades were made from (the famous) Wardlow steel.
Then i found these posts from 2017 on a forum:
Question: "What type of knife was used by Camillus in the early years, was it 1095 ?
I have a stockman made between 1920 and 1930, use it every day for carving, sharpest pocket knife I every had.
I am 64 years old this steel beats them all."
Answer: "Camillus forged their blades from Wardlow's best crucible steel from Sheffield England."
Reply: "All I know this blade steel is great, I carve 4 to 6 hours a day, sometime just strop and keep cutting.
My new pocket knives will not do this no matter the brand."
And from Bladeforums: "The S. & C. Wardlow steel that Camillus imported from Sheffield, England, was derived from about 8o percent pure Swedish iron ore; wide variation in heating did not injure it."
This Pathe footage from 1949 shows the actual making of the crucibles and how they were used to produce cast steel:
https://www.britishpathe.com/video/hand-made-steel-handmade-steel/query/foundries
The first reaction below almost the same footage on YouTube (but without sound) reads this:
"George Goodwin, puddling clay for the making of pots for melting crucible steel, looks like the old Benjamin Huntsman works on Coleridge Rd.
I started work there in 1968 as a lad in the forge, George by then was much older and working in the warehouse, he told us lads of these days making pots, and was still a very fit and muscular guy, bulging biceps for a pensioner a fantastic bloke.
A piece of Sheffield history here..... Bob."
Thanks for the video and the amazing glimpse into the past of crucibles production. :super:
Abu
Originally the blade used to be full convex ground, but sometime during it's existence a previous owner had sharpened a bit of a rough secundairy bevel into it.
So i reground the blade by hand to full convex again on 400 grit wet & dry using WD40 oil as a lubricant on a medium hard rubber backing (old piece of fiber reinforced conveyor belt)
The old blunt "edge" measured between 35 and 40 degrees inclusive, while the new edge apex fits almost exactly in the (specifically aimed for) 30 degrees inclusive slot of my Tormek WM200 Angle Master.
I do consider this a bit on the conservative side, as i think the steel can most likely handle a thinner edge geometry just fine, but for now i want to play it safe with this rare & valuable knife (to me anyway)
If need be further thinning can always be done later.
There is still a tiny burr on the apex, next step will be to refine the scratch pattern with probably 800 grit wet & dry.
After that the plan is to recut the swedge with a small diamond file followed by wet & dry paper & some WD40.
The handle has already been smooth sanded with 400 grit wet & dry and treated with several coats of warm Granger's wax.
Some more vintage footage about old school knife making in Sheffield:
Bridlington, October 1978
After 72 years as a blade forger in Sheffield, Albert Craven has finally decided to retire.
https://www.youtube.com/watch?v=zpeyhC-UIFg
Two knife grinders at work:
https://www.youtube.com/watch?v=qfXYBheE_Fs
A website dedicated to various things Sheffield, among which several clips related to knife making:
http://www.alexglenwilson.com/2018/05/10/little-mesters/
Footage from the 1960's where the same George Goodwin (now 77 years old) shows how he makes the crucibles:
https://www.youtube.com/watch?v=tOS05k1C7zM
Also this fascinating color documentary made in 1945 about large scale steel manufacture in Sheffield.
In the beginning there is even some footage of crucible steel manufacture.
http://film.britishcouncil.org/steel
The blade has been refined through grit 800 and 1000 wet & dry (again using WD40 on the piece of conveyor belt), removed the very fine burr on the Tormek leather wheel, and the apex can now whittle one of my chest hairs from root-to-tip at about 3.0 centimeters from the point of holding.
Also polished the aluminium pommel a bit on a felt wheel, recut the swedge with a small diamond file, and next step is to refine the swedge surfaces a bit more.
This is how the knife currently looks:
Chest hair for me is a great source of edge testing material, plus it's renewable too, :D
Maybe in the future i'm going to buy a BESS tester, but for now i'm good,
Paper ad from 1926 showing the Wade & Butcher Teddy model on top and the Pioneer, Boone, and Bowie models below:
