final beauty contest - Spring- und Automatikmesser
Spring- und Automatikmesser werden vielleicht schon bald kaum noch zu sehen sein.
Höchste Zeit für einen (voraussichtlich) letzten "Schönheitswettbewerb".
Hier zum Einstieg ein Klassiker aus Italien von Frank Beltrame.
Microtech custom Ultratech VIII Double Action OTF with stainless steel handle & blued carbon steel Damascus dagger blade from 09/2008 with serial number 001.
Specs:
Length open: 20,5 cm
Length closed: 12,0 cm
Blade length: 8,5 cm
Blade thickness: 3,28 mm
Steel: blued carbon steel Damascus
Handle material: satin finished stainless steel
Weight: 162 grams
Microtech custom Scarab Double Action OTF with polished dagger blade & handle inlayed with black rayskin, blued titanium hardware & glassbreaker with ball bearing.
Specs:
Length open: 22,5 cm (including "glassbreaker")
Length closed: 13,9 cm
Blade length: 9,0 cm
Blade thickness: 3,25 mm
Steelt: most likely S30V stainless (not marked)
Handle material: hard anodized 6061 aluminum with black rayskin inlays
Weight: 104 grams
Microtech Nemesis II Single Action OTF from 06/2003
The knife opens automatically by pushing the button, after which the blade can be pulled back with a lever inside the back of the handle.
Specs:
Length opened: 21,6 cm
Length closed: 12,2 cm
Blade length: 9,2 cm
Blade thickness: 3,75 mm
Steel: most likely 154CM stainless (not marked)
Weight: 94 grams
Microtech Combat Talon III Single Action OTF from 06/2003
Specs:
Length open: 21,5 cm
Length closed: 12,5 cm
Blade thickness: 4,44 mm
Weight: 111 grams
Microtech Exodus Single Action OTF from 08/2001
Specs:
Length closed: 12,7 cm
Steel: most likely 154CM, with a boron carbide coating
Weight: 116 grams
Microtech Combat Talon II Single Action OTF from 02/2000 with blade ground by Walter Brend.
Microtech CMTX5-A from 10/2004
This knife opens automatically by pushing on the end of the pocketclip, underneath which is the actuator which releases the blade.
Specs:
Length open: 20,6 cm
Length closed: 11,6 cm
Blade length: 8,9 cm
Blade thickness: 3,23 mm
Steel: S30V stainless with black coating
Handle material: brown canvas Micarta on titanium liners
Weight: 112 grams
Microtech Scarab Executive OTF tanto, and outside of the claw logo on the handle the knife is sterile (no markings)
The blade opens by pushing the actuator forward, and closes again by pulling it backwards.
Specs:
Length open: 20,4 cm
Length closed: 11,7 cm
Steel: most likely S30V stainless
Handle material: hard anodized 6061 aluminum without inserts
Weight: 115 grams
Microtech Lightfoot L.C.C D/A Carbon from 09/2001 (4th generation with anodized aluminum bolsters)
The knife can be opened manually with the thumbstuds, but also automatically by swiveling the left bolster a bit to the right.
Specs:
Length open: 21,0 cm
Length closed: 11,9 cm
Blade thickness: 3,77 mm
Steel: stonewashed 154CM stainless
Handle material: Carbonfiber scales & anodized aluminum bolsters on steel liners
Weight: 167 grams
Length open: 21,7 cm
Length closed: 12,4 cm
Blade thickness: 2,99 mm
Steel: Explosion Damascus
Handle material: stainless steel with a combination of mirror finishes & 2000 grit finishes with "Barb Wire" engraving.
Weight: 152 grams
Comes in padded pouch
(specks in some of the pics are dust particles in reality)
Steel: Eggerling Damascus
Handle material: stainless steel with a combination of mirror finishes & 2000 grit finishes, multicolor engraving with 24 kt gold domes and screws plus a 1,5 Zirconia in the firing button
Weight: 134 grams
