KTL-Store
hat etwas länger gedauert, doch hier sind nun Daten und Bilder zur RRT-0:
Model: RRT-0 (R2)
Specially designed for Military, Law Enforcement, Self-defense, Hunting, Search & Rescue and Outdoorsman
The Rapid Response Control Ring allows the user to easily select different brightness level
Five levels of brightness to choose
Optional low / lower low mode
Stainless steel rapid response control ring, very reliable and durable
Stainless steel bezels protect the head and tail cap from drops and impacts
Stainless steel crenulated bezel can be used as a glass breaker or defensive tool
CREE R2 LED,
Max output reaches 240 lumens with an effective range of 200 meters
New hybrid reflector specially designed for CREE LED, which allows for better beam quality, efficiency and throw capability
Newly designed high efficiency broad voltage drive circuit
Compatible with both CR123 and RCR123 rechargeable Li-ion batteries
Floating positive end, designed for better contact
Built-in intelligent Li-ion rechargeable batteries protection circuit
Tailstand
Impact-resistant accords with US MIL-STD-810F
IPX 8 standard waterproof
Dimension:
Head/Tail Diameter 25.4mm
Tube Diameter 20.5mm
Total Length 97mm
Weight: 86g
Output & Runtime:
Using CR123 Battery
High Mode 240 Lumens, 45 min
Daily Mode 50 Lumens, 7.5 hours
Mid Mode 25 Lumens, 12 hours
Low Mode 10 Lumens, 20 hours
Lower Low Mode 1 Lumen, 100 hours
Using AA Battery
High Mode 180 Lumens, 45 min
Daily Mode 50 Lumens, 5 hours
Mid Mode 25 Lumens, 10 hours
Low Mode 10 Lumens, 15 hours
Lower Low Mode 1 Lumen, 80 hours
Das hört sich doch gut an, oder?
Frank
Model: RRT-0 (R2)
CREE R2 LED,
Tailstand
Dimension:
Total Length 97mm
Weight: 86g
Output & Runtime:
Using CR123 Battery
Using AA Battery
Frank
RRT-0.jpg25,5 KB · Aufrufe: 353 -
RRT-0_2.jpg29,7 KB · Aufrufe: 270 -
RRT-0_3.jpg28,4 KB · Aufrufe: 413 -
RRT-0_5.jpg32,7 KB · Aufrufe: 317 -
RRT-0_6.jpg30,8 KB · Aufrufe: 1.366 -
RRT-0_7.jpg22,2 KB · Aufrufe: 264 -
RRT-0_10.jpg25,1 KB · Aufrufe: 305 -
RRT-0_11.jpg28,6 KB · Aufrufe: 277 -
