JETBeam RRT-0
hat etwas länger gedauert, doch hier sind nun Daten und Bilder zur RRT-0:
Model: RRT-0 (R2)
Specially designed for Military, Law Enforcement, Self-defense, Hunting, Search & Rescue and Outdoorsman
The Rapid Response Control Ring allows the user to easily select different brightness level
Five levels of brightness to choose
Optional low / lower low mode
Stainless steel rapid response control ring, very reliable and durable
Stainless steel bezels protect the head and tail cap from drops and impacts
Stainless steel crenulated bezel can be used as a glass breaker or defensive tool
CREE R2 LED,
Max output reaches 240 lumens with an effective range of 200 meters
New hybrid reflector specially designed for CREE LED, which allows for better beam quality, efficiency and throw capability
Newly designed high efficiency broad voltage drive circuit
Compatible with both CR123 and RCR123 rechargeable Li-ion batteries
Floating positive end, designed for better contact
Built-in intelligent Li-ion rechargeable batteries protection circuit
Tailstand
Impact-resistant accords with US MIL-STD-810F
IPX 8 standard waterproof
Dimension:
Head/Tail Diameter 25.4mm
Tube Diameter 20.5mm
Total Length 97mm
Weight: 86g
Output & Runtime:
Using CR123 Battery
High Mode 240 Lumens, 45 min
Daily Mode 50 Lumens, 7.5 hours
Mid Mode 25 Lumens, 12 hours
Low Mode 10 Lumens, 20 hours
Lower Low Mode 1 Lumen, 100 hours
Using AA Battery
High Mode 180 Lumens, 45 min
Daily Mode 50 Lumens, 5 hours
Mid Mode 25 Lumens, 10 hours
Low Mode 10 Lumens, 15 hours
Lower Low Mode 1 Lumen, 80 hours
Das hört sich doch gut an, oder?
Frank
Akso das Tailcap hat ja mal nicht wenig Ähnlichkeiten mit dem
der Aleph-Modell...! :argw:
Aber ganz ehrlich, mir gefällt die Jetbeam seeehhhhrrrrrr! :super: :D
GEILLLLL!!!!! :super:
Bin ich froh, die Lampe bestellt zu haben. Kein sinnloser Strobe, und kein noch sinnloserer Stand-by wie die großen Brüder!
Noch handlich, beinahe unendliche Möglichkeiten der Energieversorgung, sehr angenehmens UI, was will man mehr?
Das hier würd ich noch wollen:
1) statt der 25 Lumen einen Double - Beacon - Pulse
oder noch besser: einen I.B.S. - Control Ring
2) weniger Ringe im Beam (zumindest auf den Fotos sieht der Beam recht ungleichmäßig aus) :(
3) die neue CREE XP-G (hoffe die Bezeichnung stimmt jetzt), alleine schon wegen dem (angeblich) besseren Wirkungsgrad
Ansonsten gebe ich der Lampe mal viele Vorschußlorbeeren und ich denke, sie hat gute Chancen, meine neue EDC zu werden.
Freu mich schon irrsinnig, mit dem Teil zu spielen :D
Und das 3. Bild hat nicht wenig Ähnlichkeit mit den typischen Surefire - Grössenvergleichsbildern. :argw:
Aber das macht die Lampe nicht weniger begehrenswert für mich.
Oh wie verführerisch,
die RRT-0 kommt ohne Blink-Modi. :super:
Low ist wirklich low und auch die anderen Modi scheinen gut abgestuft,
wenn gleich nicht der Regel 4xLumen gleich doppelte Helligkeit zu entsprechen.
Ich hätte mir demnach ~240/80/20/5/1 gewünscht, da der Sprung von 240 zu 50 Lumen doch recht groß ist.
Ob das für die Praxis relevant ist, werden wir hoffentlich bald erfahren.
Die Beamshots zeigen leider sehr unschöne Ringe..., da hilft kein Wenn und Aber, da hat sich JetBeam offensichtlich den Newbees angepasst hat, die Throw beeindruckender finden, als gute Ausleuchtung.
Ich werde mich zurück halten, obwohl ich starken Kaufreiz verspüre und warte auf eine JetBeam mit identischem UI, aber Cree XP-G und OP-Reflektor.
Spätestens wenn JetBeam eine RTT mit Cree XP-G-R5, ohne Geblinke, und im Format der ST bringt, werde ich schwach.
Heinz
Heinz
Hi Heinz!
Die Frage ist ja auch, warum das nicht gleich zur Einführung auch geschehen
ist?! War die Entwicklung der XP-G noch nicht soweit?
Ich frage mich sowieso, warum sogut wie nie eine SSC P4 verbaut wird?:confused:
Wenn eine CR123 geht, geht auch eine RCR123 - und wenn eine AA geht, dann geht auch ein 14500 Akku? Anders gefragt: in welchem Spannungsbereich arbeitet der Treiber?
EDIT: ich vermute mal, 0.7-4.2V; steht ja alles oben... war 'ne lange Nachtschicht.
attachment.php
Wenn ich mir die Beamshots so ansehe ...
Paßt der OP-Peflektor der Jet-I Pro? Oder gibt es einen anderen OP-Reflektor für die RRT-0?
Das könnte mein Nachfolger meiner durchgebrannten Fenix P3D werden!
Aber die Ringe sehen wirklich grauenhaft aus! :glgl:
Erst mal abwarten....
Also mir gefällt die RRT-0 wirklich auch ausgesprochen gut. Sehr kompackt die Lampe. Leider hat Jetbeam auf Seiner seite nicht dazugeschrieben, ob man RCR123 und 14500er LIIon Akkus verwenden kann. Ich denke es spricht nix dagegen, es ist ja nur eine andere Bauform.
Gibt es für die Lampe auch ein passendes Holster. Diesen "Anclip Clipsen" traue ich nämlich gar nicht. Eine 100EUR Lampe verlieren ist nämlich richtig ärgerlich.... :haemisch:
Flavio von BugOutGear hat was von Lithium-Akkus und max 4,2 Volt geschrieben.
Ich hoffe du meinst mit anderer Bauform nur die RCR123 im Vergleich mit dem 14500 Lithium-Akku und nicht etwa die CR123 im Vergleich mit der RCR123 oder gar Alkali mit 14500?
Olaf
die Lampe ist heute gekommen, die Pakete sind gepackt. Morgen wird verschickt.
Ihr könnt euch auf eine tolle Lampe freuen!
Frank
