Test/Review zum Subcom-Folder von Chad Los Banos/Böker
Daywalker schrieb:
Mahalo much to you DrArnie, and I must say that from your pics, the SF goes well with that Strider of yours! Do take care of that Strider, and let the SF do all the "dirty work"! :D
You betcha! They've already become brothers. :D
Als ich vorhin den Clip abgeschraubt habe, ist mir ein Detail aufgefallen welches mich positiv überrascht hat: Die Clipschrauben sind mit Loctite fixiert. Das hätte ich bei dem Messer nicht unbedingt erwartet. :super:
@Chad: I removed the pocket clip and noticed that the clip screws are fixed with Lotite. For me this is a nice detail also in consideration of the price.
Schönen Gruß
BlackBlade
beagleboy schrieb:
@ Chad: Who the hell is bugleboy ? :argw: ;)
*UGH*!!! My apologies my friend! It was late and my mind was laready wrecked by the translations of altavista! :glgl: Sorry about that BEAGLEboy!
By the way, I still have no idea about MarioR's question. :confused: :(
God bless and mahalo :super:
Chad
CLB DESIGNS :ahaa:
Aloha BlackBlade,
Mahalo sir, for your support and great pictures! Cripes, that Strider is a BEAST of a knife! :staun: Yes, once you discover how to open the SF, it opens fast and sure, solid lockup all the time. Very useful in public or in crowds...hopefully your Emerson will be less scratched now that it has a "subordinate" to do the "dirty work"! :super:
Thanks for your support and again for the great comaprison pics!
God bless and take care :super:
Chad
CLB DESIGNS :ahaa:
Mahalo DrArnie!
What a great team, IMHO! I am glad that the SF will be of service to you. I agree with you in that the SF makes for a great using knife, pretty much anywhere, and is an expendable one. I mean, let's face it, regardless of the steel, it cuts just as well as that Strider, yet is less costly to replace should it get lost or damaged. The price point is just a dream for the SF...if you shop around right! :super:
Thanks DrArnie for the great pic! ;)
Chad
CLB DESIGNS :super:
I think that it is very tricky to release the knife to put it back together... (bad english)
without any fingernail i wouldn't be able to put it together.
Is there a trick i don't know? Something like pushing the other end of the knife to release it?
I hope that you understand me quit a little bit...
@Chad: I'm glad you like the pics! :)
MarioR stated that he has some problems to close the Subcom one-handed. For now he uses two hands for closing.
In the following, I will try to explain the one-handed method to him.
@MarioR: Nimm das Messer so in die Hand, dass es mit dem Griffrücken zu deinen Fingern zeigt. Mittel-, Ring- und kleiner Finger sollten dabei den Griff festhalten. Mit dem Daumen drückst du nun die Klingenverrigelung zur Seite. Sobald die Klinge entriegelt ist, drückst du mit dem Zeigefinger gegen den Klingenrücken und klappst die Klinge solange langsam zu, bis sich die Klingenwurzel unter die Verriegelung geschoben hat. Nun nimmst du den Daumen von der Verriegelung und damit aus dem Weg der Klinge, und legst ihn auf den Bereich um die Achsschraube. Nun kannst du die Klinge mit dem Zeigefinger weiter einklappen, auf dem letzten Stück nimmst du besser den Daumen.
Mit etwas Übung kannst du den Subcom Folder so ohne Probleme einhändig schließen. Führe den Vorgang zuerst langsam und vorsichtig aus, da sonst die Verletzungsgefahr steigt.
Ich hoffe ich konnte dir weiterhelfen?!
Schönen Gruß
BlackBlade
Aloha MarioR and BlackBlade!
Thank you both!
@MarioR, yes, I understood you perfectly well! Don't worry about the "bad english"...it is my first language and I still don't know how to use it properly! :irre: Uh, BlackBlade's explaination should be most useful...if not, we'll try again.
@ BlackBlade: Mahalo my friend!
Thanks everyone, good night and God bless! :super:
Chad
CLB DESIGNS :ahaa:
Danke für die Hilfe euch beiden.
Ich habe das Messer tatsächlich flasch gehalten.
Ich finde es wirklich klasse das ihr hier auch so blutigen Anfängern wie mir Fragen beantwortet ohne schnippisch zu werden.
Jetzt gefällt mir das Messer noch besser.
@Daywalker Yes, BlackBlades explaination is very useful. Now i'm quiet happy.
einen kritikpunkt habe ich noch: das dingen ist zu klein! ich habe ihn verlegt und finde ihn nicht wieder, hilfe!
Hab meines eben von der Post abgeholt.
Nettes kleines Teil.
Was mir noch aufgefallen ist, die vordere Griffschale ist im Bereich der Fingermulde nach innen abgeschrägt. Hat das irgendeinen tieferen Sinn oder ist das nur ein "Designfehler" ?
Und die Sache mit dem Stud und dem Öffnen mit Handschuhen kann ich ja noch nachvollziehen. Aber schließen mit Handschuhen :confused: Ich hab ja schon mit meinem dicken Daumen leichte Probleme, das Teil zu schließen.
@ Chad
Cute little Folder :super:
The handle in the finger hole is tapered inside. is there any funktion for or is it only "design-error :D"
Stud Location: Tricky with this little folder. I could have placed it further towards the pivot pin, however with the use of gloves, I noticed they got pinched,
Openning with gloves I can follow, but what about closing? It is tricky (with my thumb) without gloves, how can it work with gloves?
Das mit der abgeschrägten Griffschale hat einfach den Sinn, den Zwischenraum zwischen arretiertem Liner bei geöffneter Klinge und der Innenkante der Griffschale zu vergrößern, damit man den Liner (bei diesem sehr schmalen Messer) zum Schließen des Messers besser greifen kann.
Sagt mir zumindest die Logik und Haptik.
Ich habe übrigens im Thread mal wieder ein bißchen Plaudereien aufgeräumt, damit der Thread einigermaßen übersichtlich bleibt.
Ankündigungen von Kaufabsichten o.ä. sind zwar nett, fallen aber nicht unbedingt unter "Erfahrungen mit dem Subcom Folder". ;)
Aloha teachdair,
I am sorry, but I cannot figure out what babelfish is trying to say that you're saying. :( Perhaps later I can be of some help with a translation that is accurate.
Chad
CLB DESIGNS :ahaa:
@ Chad
Aloha schwartzbunt,
Thanks for your support and great question! All I can honestly say is that since the framelock on the SF has no ridges to help disengage it, it will just take some practice. Very simple with or w/o gloves after some time getting used to it.
The taper you speak of was not part of my design. :rolleyes: That taper simply aids in keeping the Zytel scale attached to the steel liner that lies beneath it. ;)
Again, I apologize if I did not answer correctly...sharp eyes you got though...I was wondering when someone was going to ask about that taper! :super:
God bless and thank you :super:
Chad
CLB DESIGNS :ahaa:
I guess the "tapering" we are talking about is the thumb ramp in the Zytel scale which makes it easier for the thumb to disengage the lock (red marked area on picture below).
@ schwartzbunt:
davon sprechen wir doch, oder?
@ chad:
the tapering you are talking about is the complete "embedding" (rigt word?) of the steel liner in the Zytel scale?
BTW: teachdair was joking the knife is too small, so he lost it and can´t find it again...
ich habe heute das zytel an der von beagleboy markierten stelle etwas runtergeschliffen. somit ist es wesentlich einfacher den lock zu öffnen und das messer zu schliessen. sollte nun auch mit handschuhen gut klappen. der lock kann trotzdem nicht versehentlich geöffnet werden.
Aloha Beagleboy!
Hmmmmm, it does appear that the "taper" does aid in closing by having less material between the two scales to disengage the lock. However, I can unlock the SF right before the first texture notch where there is no taper...
I suppose this little detail which I thought merely helped the Zytel adhere to the ss liner was done by Magnum to ease closing! :rolleyes:
Mahalo once again beagleboy! :super:
@ Thanks everyone :super:
God bless,
Chad
CLB DESIGNS :ahaa:
hi there!
ah, sod of on the steel boker used, i dont mind if i have to resharpen it once a week or once a month!
and a 420 with a proper heatthread is very close to a aus8, if not superior.
but the new, elongated clip seems to be a great idea, although the short clip works as a kind of lockbar stabiliser, was it intended?
ach scheiss auf den stahl, es ist mir wurscht ob ich das messer einmal die woche oder einmal den monat nachschaerfen muss.
ein 420 mit ner guten wb ist einem aus 8 nahezu gleichwertig, wenn nicht sogar ueberlegen, falls die wb nicht sooo optimal war beim aus8.
der neue, verlaengerte clip scheint ne tolle idee zu sein, obwohl der kurze clip eine art lockbar stabiliser war. war das beabsichtigt?
Aloha teachdair!
Thank you for your kind words and I agree about the steel. This 420J2 that Magnum has used is very comparable to AUS6 and even AUS8...I am attrubuting this to the thin, 2mm blade.
A longer clip will aid in opening as well as prevent "pocket escapes". :lach: However, I do not understand what you mean by the clip stabilizing the lockbar? Sorry. :(
God bless and mahalo for your thoughts :super:
Chad
CLB DESIGNS :ahaa:
