Gerade hier gefunden - vielleicht von Interesse:
Cytac-3.7V Li-ion 18650 2200mAh
Specifications:
(1) Capacity:
a) Nominal: 2,200mAh
b) Min.: 2100mAh
(2) Dimensions:
a) Diameter: 18+/-0.2mm
b) Height: 65+/-0.5mm
(3) Weight (typical): approx. 48g
(4) Nominal voltage: average 3.7V
(5) Cut-off voltage: 3.0V
(6) Internal impedance: less or equal to 80 milliohm
(7) Cycle performance: 90% of initial capacity at 400 cycles
(8) Cycle life: > 500 cycles
(9) Charge: current = 0.5C mA, voltage = 4.2V, end current = 0.01mA
(10) Discharge: current = 0.5C mA, end voltage = 3.0V
(11) Max.charging current: 1C mA
(12) Max.discharging current 1C mA (for continuous discharge)
Specifications:
(1) Capacity:
b) Min.: 2100mAh
(2) Dimensions:
