Rock'n'Roll
MF Ehrenmitglied
Da wir mittlerweile über Gefühle und Schleifkurse in Gerümpel-Küchenschubladen gelandet sind, bringe ich mal in Erinnerung, um was es hier eigentlich aktuell ursprünglich ging: D2
Summary and Conclusions
The finer carbide structure of PSF27 provides superior toughness vs conventional D2. And the yet finer structure of CPM-D2 gives it better toughness than either PSF27 or D2. A recommended heat treatment would be 1850-1900°F for 30 minutes, plate quench, cryo, and temper 300-500°F. Without cryo the austenitizing temperature should be no higher than 1875°F. There are alternative grades that have more desirable properties, in my opinion, such as CPM-154 for better corrosion resistance, 10V/Vanadis 8/K390 for better edge retention, or CPM CruWear for better toughness. And 154CM can be used as a relatively low cost stainless steel with comparable toughness and edge retention to conventional D2. However, D2 has been a mainstay in knives for decades now and these heat treatment recommendations will hopefully help those knifemakers and companies that choose to use it.
R’n‘R
R’n‘R
